It is currently Tue Jun 25, 2024 6:44 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 21, 2023 7:16 pm
Using a single cycle $03 opcode works quite well, Bill. A simple and clever way to end up in a sync cycle after a reset sequence without having to worry about how many cycles are required for the sequence. Just tested it on my production board by sending ten $03 bytes after taking reset high so the 6502 PC should be near $303 after the reset sequence...
   *  core 'blind interface' functions                                          *
   void uReset()                      // ****************************************
   { byte i = 10;                     //
     clk(1);                          // clock hi
     res(0);                          // reset = 0, start reset sequence
     uPull(ram); uPull(ram);          // send a couple clocks while reset lo
     res(1);                          // reset = 1
     do                               // push ten $03 bytes
     { uPush(0x03);                   //  "
     } while(i--);                    //  "
PostPosted: Sat Oct 21, 2023 7:20 pm
Is there no way to sync up using only legit opcodes?
PostPosted: Sat Oct 21, 2023 7:38 pm
... good question...
PostPosted: Sat Oct 21, 2023 9:37 pm
How about PHA then NOP and a hi-Z cycle? If sync is on PHA then the NOP is ignored and the third cycle is a write by the CPU. If sync is on NOP then it's a NOP and the bus floats for the third cycle but it's ignored. Either way there'll be a sync on the fourth cycle. You can either issue the PHA at the earliest time the reset might be complete, or precede it with some 2-cycle NOPs to protect against being in the middle of a possibly longer instruction.
If the third cycle bring a write is a problem then maybe LDA <zp> would be OK in its place.
PostPosted: Sat Oct 21, 2023 10:20 pm
What if you repeated "LDA $EA" ... since $EA is NOP, if you start in the middle of a LDA $EA, it's a NOP and you start at the beginning of the next "LDA $EA".
Edit: I am not a hardware hand, but since that is repeated %1010.1001 %1110.1010, which is %[11][01][11][00].[11][00][01][10], it seems a tri-state driver with DRIVE_Q0-7 on the Data Bus, with /DRIVE_OE on being in the start-up mode, and wiring DRIVE_D2,D4 to GND and DRIVE_D3,D5,D7 to VCC gets you part of the way there. It seems a toggling flip flop driven by PHI2 with its Q inputting DRIVE_D1,D6 and /Q inputting DRIVE_D0 would get you there. IIUC, you can wire up a 7400 to do a toggling flip flop on PHI2=H.
PostPosted: Sat Oct 21, 2023 10:55 pm
Yes exactly. Another option that's interesting regarding Jeff's minimal 3 wire system (which I'm hoping to get back to tomorrow) is 6xEA, 00, 6xEA. The first six EAs ensure that either the 00 is an opcode fetch (and we execute a BRK sequence of seven cycles), or the EA afterwards is an opcode fetch and we execute three NOPs. Either way, the next cycle after this sequence will be an opcode fetch. (With Jeff's latest scheme the two-cycle instruction is not actually NOP, but any two cycle instruction is fine there.)
PostPosted: Mon Oct 23, 2023 10:13 pm
Michael wrote:
The clock and reset transition timing does make a difference. I can consistently force a 7 cycle or 8 cycle sequence by setting the reset pin during the hi or lo portion of PHI2, respectively. That's why I'm curious about your hardware.
Dear Michael, the different behaviour with my board gave me no peace. I have simplified the experimental setup and only feed in RESB and PHI2 with a minimal programme and check the level of VPB after each step.
If the rising edge of RESB occurs during the low phase of PHI2, I always get the same result:
  1  resb H  phi2 H  vpb H
  2  resb L  phi2 H  vpb H
  3  resb L  phi2 L  vpb H
  4  resb L  phi2 H  vpb H
  5  resb L  phi2 L  vpb H
  6  resb L  phi2 H  vpb H
  7  resb L  phi2 L  vpb H
  8  resb L  phi2 H  vpb H
  9  resb L  phi2 L  vpb H
 10  resb H  phi2 L  vpb H
 11  resb H  phi2 H  vpb H
 12  resb H  phi2 L  vpb H
 13  resb H  phi2 H  vpb H
 14  resb H  phi2 L  vpb H
 15  resb H  phi2 H  vpb H
 16  resb H  phi2 L  vpb H
 17  resb H  phi2 H  vpb H
 18  resb H  phi2 L  vpb H
 19  resb H  phi2 H  vpb H
 20  resb H  phi2 L  vpb H
 21  resb H  phi2 H  vpb H
 22  resb H  phi2 L  vpb H
 23  resb H  phi2 H  vpb H
 24  resb H  phi2 L  vpb L
 25  resb H  phi2 H  vpb L
 26  resb H  phi2 L  vpb L
 27  resb H  phi2 H  vpb L
 28  resb H  phi2 L  vpb H
 29  resb H  phi2 H  vpb H
 30  resb H  phi2 L  vpb H
 31  resb H  phi2 H  vpb H
 32  resb H  phi2 L  vpb H
 33  resb H  phi2 H  vpb H
vpb low in step 24
If the rising edge of RESB occurs during the high phase, the result varies:
 20  resb H  phi2 L  vpb L
 21  resb H  phi2 H  vpb L
 22  resb H  phi2 L  vpb L
 23  resb H  phi2 H  vpb L
 24  resb H  phi2 L  vpb H
 25  resb H  phi2 H  vpb H
 26  resb H  phi2 L  vpb H
 27  resb H  phi2 H  vpb H
vpb low in step 20
vpb low in step 22
Repeating the two experiment several times gives the same results:
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 24
vpb low in step 22
vpb low in step 20
vpb low in step 20
vpb low in step 20
vpb low in step 20
vpb low in step 20
vpb low in step 20
vpb low in step 20
vpb low in step 22
vpb low in step 20
vpb low in step 22
vpb low in step 22
vpb low in step 22
vpb low in step 22
vpb low in step 22
vpb low in step 20
vpb low in step 20
vpb low in step 22
vpb low in step 22
vpb low in step 22
If I have understood you correctly, these variations do not appear in your set-up? This seems very strange to me. Sorry if I have mixed things up!
PostPosted: Mon Oct 23, 2023 10:29 pm
$A9 $EA seems like a very good idea to me. However, my system seems to behave completely predictably if the rising edge of RESB occurs during PHI2 low.
To be on the safe side, I passively check the data bus for the expected values during write commands. If the feed were not synchronous, this should be noticed immediately at this point and I can repeat the reset sequence.
Or am I missing something?
Users browsing this forum: No registered users and 63 guests
