ElEctric_EyE wrote:
Edit:And speaking of the 65xx/68xxx architecture, if you pull up a 68020 datasheet, you'll see virtual machine/supervisory concepts dated back to 1992. (A superiority I had to point out compared to the 8086 evolution, maybe a year or two have passed since Intel has posed a virtual machine concept)
I must disagree with this, having used both architectures extensively, both professionally and while growing up.
The 68000 had a nearly completely virtualizable instruction set. Only MOVE.W SR, Dn instruction violated the virtualization capability; the 68010 (not 020!) solved this one problem in its entirety, thus fixing the virtualization problem once and for all. This would put the 680x0's virtualization features as far back as early 80s -- 1982ish, IIRC.
With regards to supervisor modes, though, the Intel architecture introduced this along with Protected Mode's appearance in the 80286 processor, back as far as 1987(ish). Protected mode introduced a Multics-like 4-ring security model. Ring 3 is the lowest privilege level, while ring 0 is the highest. Hence, your applications ran in ring 3, while the OS kernel ran in ring 0. Hence the origin of the phrase, "This code runs in ring 0."
Like the 68000's MOVE SR, though, the SMSW instruction was unprivileged, granting read-access to the protected mode bit, and thus undermining its ability to institute a true virtual machine. It also had a hardware bug, wherein once you engaged protected mode, you stayed in protected mode forever. The only work-around was to physically reset the CPU. This is why running DOS applications in OS/2 1.0 were so damn slow -- every time that thread took control, the CPU had to undergo a complete reset sequence!
The 80386 was the first processor to fix the real/protected-mode bug (some say that the 80286 was a rushed beta of the 80386 to try and fend off the 68000's success; however, I question this. It IS known that the 80x86 architecture inherited many of its protected-mode features and descriptor tables from the i432 architecture, though), but true support for virtualization didn't appear until the Pentium-IV series of processors!
