1) My lack of knowledge and understanding of what I think I'm attempting to do/the way I'm going about it,
2) An issue with Wincupl,
3) An issue with my verification process.
Using the address pins A15 to A5 inclusive, I am attempting to create the following memory map for my WDC65C02 system to use just one page for IO...
0000 - 7F00 RAM
7F00 - 7F1F IO0
7F20 - 7F3F IO1
7F40 - 7F5F IO2
7F60 - 7F7F IO3
7F80 - 7FFF IOX
8000 - FFFF ROMCode: Select all
________
CLK x---|1 24|---x Vcc
RW x---|2 23|---x IOX_CS
A15 x---|3 22|---x IO3_CS
A14 x---|4 21|---x IO2_CS
A13 x---|5 20|---x IO1_CS
A12 x---|6 19|---x IO0_CS
A11 x---|7 18|---x ROM_CS
A10 x---|8 17|---x RAM_CS
A9 x---|9 16|---x OE
A8 x---|10 15|---x WE
A7 x---|11 14|---x A5
GND x---|12 13|---x A6
|________|However, when I hook the CPLD up to my Arduino to check the logic between the address pins and the chip selects, I get the following (I reproduce the output around 8000 where all the action should happen)...
AAAA AAAA AAA R R I I I I I
1111 1198 765 A O O O O O O
5432 10 M M 0 1 2 3 X
0111 1110 101 -> 0 1 1 1 1 1 1
0111 1110 110 -> 0 1 1 1 1 1 1
0111 1110 111 -> 0 1 1 1 1 1 1
0111 1111 000 -> 1 1 1 0 1 1 1
0111 1111 001 -> 1 1 1 0 1 1 1
0111 1111 010 -> 1 1 1 1 1 0 1
0111 1111 011 -> 1 1 1 1 1 0 1
0111 1111 100 -> 1 1 1 1 1 1 0
0111 1111 101 -> 1 1 1 1 1 1 0
0111 1111 110 -> 1 1 1 1 1 1 0
0111 1111 111 -> 1 1 1 1 1 1 0
1000 0000 000 -> 1 0 1 1 1 1 1
1000 0000 001 -> 1 0 1 1 1 1 1
1000 0000 010 -> 1 0 1 1 1 1 1Code: Select all
0111 1111 000 -> 1 1 0 1 1 1 1
0111 1111 010 -> 1 1 1 1 0 1 1
1000 0000 010 -> 1 0 1 1 1 1 1Why do 0111 1111 000 and 0111 1111 001 give the same output? (as does 0111 1111 010 and 0111 1111 011).
I have tried 3 different ways of inputting the logic into Wincupl (becoming more verbose each time) - they all pass with no errors and provide the same result when testing. Here is my latest offering...
Name 65C02GlueLogic ;
PartNo 00 ;
Date 13/08/2023 ;
Revision 00 ;
Designer DRG ;
Company ;
Assembly ;
Location ;
Device g22V10 ;
/* Input */
Pin 1 = CLK;
Pin 2 = RW;
Pin [3..11] = [A15..7];
Pin [13..14] = [A6..5];
/* Output */
Pin 15 = WE;
Pin 16 = OE;
Pin 17 = RAM_CS;
Pin 18 = ROM_CS;
Pin 19 = IO0_CS;
Pin 20 = IO1_CS;
Pin 21 = IO2_CS;
Pin 22 = IO3_CS;
Pin 23 = IOX_CS;
/* Local Variables */
ROM = A15;
IO = !A15 & A14 & A13 & A12 & A11 & A10 & A9 & A8; /* Temp variable */
IO0 = IO & !A7 & !A6 & !A5;
IO1 = IO & !A7 & !A6 & A5;
IO2 = IO & !A7 & A6 & !A5;
IO3 = IO & !A7 & A6 & A5;
IOX = IO & A7;
RAM = !(IO0 # IO1 # IO2 # IO3 #IOX # ROM);
!WE = CLK & !RW;
!OE = CLK & RW;
!RAM_CS = RAM;
!ROM_CS = ROM & RW;
!IO0_CS = IO0;
!IO1_CS = IO1;
!IO2_CS = IO2;
!IO3_CS = IO3;
!IOX_CS = IOX;Code: Select all
FIELD Address = [A15..5];
FIELD Decodes = [RAM, !IO0_CS, !IO1_CS, !IO2_CS, !IO3_CS, !IOX_CS, ROM];
/* Logic */
TABLE Address => Decodes {
[0000..7EFF] => 'b'1000000;
[7F00..7F1F] => 'b'0100000;
[7F20..7F3F] => 'b'0010000;
[7F40..7F5F] => 'b'0001000;
[7F60..7F7F] => 'b'0000100;
[7F80..7FFF] => 'b'0000010;
[8000..FFFF] => 'b'0000001;
/* Logic */
RAM = Address:[0000..7EFF];
IO0 = Address:[7F00..7F1F];
IO1 = Address:[7F20..7F3F];
IO2 = Address:[7F40..7F5F];
IO3 = Address:[7F60..7F7F];
IOX = Address:[7F80..7FFF];
ROM = Address:[8000..FFFF];
!WE = CLK & !RW;
!OE = CLK & RW;
!RAM_CS = RAM;
!ROM_CS = ROM & RW;Code: Select all
/* Logic */
!WE = CLK & !RW;
!OE = CLK & RW;
!RAM_CS = RAM;
!ROM_CS = ROM & RW;
!IO0_CS = IO0;
!IO1_CS = IO1;
!IO2_CS = IO2;
!IO3_CS = IO3;
!IOX_CS = IOX;I'm hoping someone from the forum can shed some light onto this as I have done as much self-help as I am able, trawling this forum and Google but not coming up with anything that highlights the problem.
Thanks.
Dave
