It is currently Fri May 10, 2024 5:16 pm
PostPosted: Sat Jul 15, 2023 2:53 pm
Hi everyone,
I've been experimenting with Atmel's programmable logic ICs and felt frustrated by the lack of a nice development workflow for them. Many people here have suggested using WinCupl's command-line tools, but a good example of how to do that was not easy to find.
So, I've created cupl.bat, which automatically compiles and fits a design (if necessary, depending on the "Device" tag in the pld file). The source code is available on my GitHub here https://github.com/adrienkohlbecker/cupl.bat and I'm also attaching it below.
My workflow, for now, is to connect to a Windows VM and edit my PLD with Notepad++. I have mapped this batch file to F6 in the editor, and it seems to work well enough for compilation and fitting. I'm more of a MacOS/Linux guy, so this is my first time writing a batch file and there may be obvious changes to make.
All feedback is welcome!
cupl.bat-revB.zip [3.47 KiB]
Downloaded 60 times
BB816 Computer YouTube series
PostPosted: Mon Jul 17, 2023 8:16 pm
Hi Akohbecker
Thanks for this. I'll give it a test 'n tune when I start working on my next ATF1504 or 8 design.
PostPosted: Mon Jul 17, 2023 10:05 pm
Hi Adrien, it looks useful for Windows use, and you've used some pretty advanced features if it's your first batch file!
Did you try my Wine-based scripts at all? As I find they do everything I need in Linux, to the point that I don't need to run a VM or anything like that.
I also found that I had to work a bit harder on the output to get it to give nice results for various different error conditions, as the way different errors are reported by WinCupl was a bit haphazard. (There's also more to do there for sure, my script sometimes hides errors that would be interesting for the user to see.)
PostPosted: Tue Jul 18, 2023 7:43 am
banedon wrote:
Hi Akohbecker
Let me know how that goes!
Thanks, let's call it Stack Overflow-driven programming :mrgreen:
I did, however I had trouble getting cupl to run properly. I was trying to run it on a Linux VM, but my main machine is an ARM Mac, and between Intel emulation and the hypervisor, it crashed with an illegal instruction error. I did not try on a native Linux box, as by then the effort was similar to connecting to my native Windows machine. I also figured it will be easier to run ATMISP natively, as I'm working with ATF150x parts and I haven't found any reference to running it headless.
I'm going to try and automate ATMISP using AutoHotKey next, so it can generate the svf file on Windows and I can program the device using my Mac.
PostPosted: Thu Jul 27, 2023 2:14 pm
Making progress on getting CUPL programming to a bearable state.
I was able to move my CUPL editing and device programming to my main Mac M2 machine. I'm using UTM (QEMU under the hood), to virtualize Windows 11 ARM edition. (Guide to follow here: https://docs.getutm.app/guides/windows/). Inside Windows 11 ARM, both WinCUPL and ATMISP work flawlessly so far through Microsoft's translation layer. Finally, using UTM's USB sharing feature, I'm able to plug my Atmel programmer directly into the VM, and to program a CPLD successfully.
I did have some trouble initially with FTDI drivers, but putting the FTD2XX.DLL file found in this archive (https://ftdichip.com/wp-content/uploads ... utable.zip) inside the ATMISP directory made it work. I did have to use the one from the "x86" folder.
I also switched my editor to Visual Studio Code, with the build actions below. To use ATMISP like this you need to run it once manually to configure your device, and use it to save a .chn file with the same name of your .pld next to it. The following extension has syntax highlighting for CUPL: https://marketplace.visualstudio.com/it ... ighlighter
Next goals are : automate ATMISP to generate the svf file, and move to VSCode Server so I can edit and program natively on Mac without using the VM's GUI.
    // See https://go.microsoft.com/fwlink/?LinkId=733558
    // for the documentation about the tasks.json format
    "version": "2.0.0",
    "tasks": [
            "label": "cupl",
            "type": "shell",
            "group": {
                "kind": "build",
                "isDefault": true
            "command": "C:\\Wincupl\\Projects\\cupl.bat ${fileDirname}\\${fileBasenameNoExtension}.pld"
            "label": "atmisp",
            "type": "shell",
            "group": "build",
            "command": "C:\\ATMISP7\\ATMISP.exe ${fileDirname}\\${fileBasenameNoExtension}.chn"
Users browsing this forum: AndrewP and 1 guest
