JimBoyd wrote:
I failed to consider the case where a screen might not contain source to compile but commands to run like a script.
I use blocks like this all the time, and often have blocks that load other blocks with
LOAD and
THRU. I usually set the base, if it's important, right at the top and set it to decimal right at the end. I would like to make some words that save and restore the old base so that I can put it back the way it was, but it hasn't been a big enough issue to focus on and I just use the stack to hold the old base when I really need to do that.
You showed your co-routine method earlier in this thread and I was able to get your co-routine method to work in Tali (even though it's STC and your forth was ITC), so I will probably implement your
RB (Restore Base) word that way when/if I get around to it.
JimBoyd wrote:
This may not be necessary because Fleet Forth's NUMBER? accepts a leading conversion base specifier ($,# or %) in a numeric string.
Tali2 supports this as well, and I've recently started to make use of it. It's actually a much better solution all around, in my opinion, because the person reading the code (which will probably be me at a later date) can easily tell $100 from #100 from %100 without having to figure out what the base is at that moment. It also allows for multiple bases to be used easily in the same screen, such as looping a decimal number of times while accessing a hex address with a binary mask.
