glitch wrote:
The Scholar definitely has some features that makes it nicer to use with a dumb terminal, too.
It's been a while, but I seem to recall multi-session support by both the terminal, modem, and terminal server.
Like many users I accessed different environments concurrently. In my case I needed to get email on a production machine, code on a development machine, and test on an integration machine. In a modern setting you would have multiple terminal windows open and switch between them. But in that era a workstation like that cost a fortune, so terminal was a more common solution. It took a bit of getting used to, but you could pretty easily juggle two or three sessions that way.
I'd be curious to see the code, especially if it's can be turned back into the Forth source code.
