Some Forth systems for the Commodore 64 have a single word, INTERPRET , to handle interpreting and compiling from a text stream. 64Forth and my own Fleet Forth are two such Forth systems. The QUIT loop executes INTERPRET to process the text stream. At least one other, Blazin' Forth, uses two different words to handle interpretation and compilation. INTERPRET handles interpretation and ] , rather than just set STATE , is the compiler. Blazin' Forth's QUIT loop executes another word, RUN , to process the text stream. I personally don't see the appeal of using two separate loops. I suppose some system implementers like the aesthetic of a separate loop for interpreting and another for compiling. The problem is the ease with which STATE can change. Blazin' Forth has some rather convoluted code to manage this. I ported one of the latest versions of my de-compiler to Blazin' Forth and this is my analysis of Blazin' Forth's QUIT loop. Here is the probable source for Blazin' Forth's QUIT (probable, because it is theoretically possible to generate the same compiled code from different, but functionally identical, source)
Code: : QUIT BLK OFF [COMPILE] [ BEGIN RP! CR QUERY RUN STATE @ 0= IF ." OK" THEN AGAIN ;
Other than having the word RUN in place of INTERPRET , Blazin' Forth's QUIT loop doesn't look unusual. Oddly, Blazin' Forth's word RUN can't be compiled by it's control flow words, but can be compiled by Fleet Forth's control flow words. Blazin' Forth's control flow words are rather restrictive. As an example, IF can have zero or one occurrences of ELSE and there are no words to swap control flow data. Blazin' Forth was written in assembly language, so this is not a problem in this instance. Here is how RUN would be written using Fleet Forth's control flow words.
Code: : RUN STATE @ IF ] STATE @ NOT IF INTERPRET AHEAD CS-ROT THEN INTERPRET THEN THEN ;
This is the source needed to produce the code displayed with SEE . Here is a cleaner version.
Code: : RUN STATE @ IF ] STATE @ ?EXIT THEN INTERPRET ;
Blazin' Forth's mystery word, the one with a length of zero and a blank for a name, is found when the text stream is exhausted.
Code: : X // TO BE CHANGED TO ZERO LENGTH BLANK NAME DONE? ON ; IMMEDIATE
DONE? is a variable in Blazin' Forth which really should have been headerless. In theory, a compiler which didn't have to test state and an interpreter which also didn't have to test state would be faster; however, they both still have to test state as part of a test for exiting their respective loops. The compiler loop, ] , needs to exit when the text stream is exhausted or if the state changes to interpreting. Likewise, the interpreter, INTERPRET , needs to exit when the text stream is exhausted or if the state changes to compiling. Actually, it doesn't have to test for a state change. If the compiler exits while the state is still compiling, it is because the text stream was exhausted and the interpreter will also exit for the same reason. I suppose the reason Blazin' Forth's interpreter checks for a state change is so it can use the same word to test for end of loop. That word is QUIT?
Code: : QUIT? ( F1-- F2 ) STATE @ <> DONE? @ OR DONE? OFF ;
Here is the compiler. Notice the test at the bottom of the loop.
Code: : ] STATE ON BEGIN ?STACK EXISTS? DUP IF 0< IF , ELSE EXECUTE CS-SWAP ELSE DROP NUMBER DPL @ 1+ IF [COMPILE] DLITERAL ELSE DROP [COMPILE] LITERAL THEN THEN THEN TRUE QUIT? UNTIL ;
and the interpreter loop.
Code: : INTERPRET BEGIN ?STACK EXISTS? IF EXECUTE ELSE NUMBER DPL @ 1+ 0= IF DROP THEN THEN FALSE QUIT? UNTIL ;
I suspect that the overhead of the test word QUIT? negates any speed advantage of this approach. I can't test Blazin' Forth's approach against Fleet Forth's without writing yet another kernel since Fleet Forth already compiles and interprets about fifty percent faster than Blazin' Forth. Both of these Forth systems use Indirect Threaded Code.
With Blazin' Forth's approach, the compiler begins compiling before the word executing it can finish. Because of this, it is difficult to effectively use colon within another definition. The halting colon definitions are an example of where this is a problem.
The latest change to Fleet Forth's interpreter makes it relatively easy to try something like this approach without the problem of premature compilation (starting to compile words before colon ( : ) , or any word executing colon, finishes.) Fleet Forth's new INTERPRET is defined like this.
Code: : INTERPRET BEGIN PAUSE NAME C@ 0EXIT HERE I/C AGAIN ; -2 ALLOT
The PAUSE is to allow multitasking while interpreting or compiling. There is no word with a blank name and length of zero. If the text stream is exhausted, WORD returns a string with length zero and this is tested. I/C is a deferred word which normally executes (I/C) to process a single blank delimited string. I built an experimental kernel which had the words INTERPRETER and COMPILER to respectively interpret or compile a single word. ] set the state to compiling and set I/C to COMPILER . [ set the state to interpreting and set I/C to INTERPRETER . INTERPRETER and COMPILER were headerless. To improve performance, ] and [ were primitives. When the system was built on top of this experimental kernel, the only other changes needed were to define this:
Code: : RI/C ( -- ) STATE @ IF ] EXIT THEN [COMPILE] [ ;
and replace the two occurrences of the phrase
Code: ['] (I/C) IS I/C
with
Code: RI/C
since (I/C) didn't exist in the experimental kernel. When test loading the same 34 screens of Forth source from blocks in ram (to eliminate the overhead of disk drive access) the experimental kernel was almost a quarter of a percent faster at loading these 34 screens. hardly any speed improvement at all. Certainly not enough for me to pursue this approach. I also tested the source for the halting colon definitions with the experimental system and it compiled fine without any changes. The halting colon definitions also worked fine. A big improvement over the situation with Blazin' Forth. This approach does introduce a slight complication. The experimental system has two pair of states instead of two states for compiling and interpreting. One pair of states is STATE is true and I/C is set to COMPILER . The other is STATE is false and I/C is set to INTERPRETER . Granted, each pair is tightly coupled and shouldn't get out of sync with STATE being true and I/C set to INTERPRETER for example. On the other hand, anything that can go wrong...
Another idea I've heard of is to have the interpreter and compiler running as separate loops, but have them run as co-routines. The words ] and [ would only change STATE . So, any thoughts on this. Is there any reason for the compiler and interpreter to be separate loops other than aesthetics?
