Rob Finch wrote:
So I guess that 32 bit addressing is the way to go for a larger code space.
32 is a lot. If I were doing it I'd use only 16 bits actually stored in memory, but with an implied scale. After the 16 bits get fetched, shift 'em left and stick some zeros on the right. If we shift 4 places, say, then we've multiplied the code space by 16 (now 1 MB), at the cost of requiring every entry point to be aligned to a 16-byte boundary. Minor downside: that results in about 8 bytes of wasted code space at the end of every routine.
I'm no fan of wasting RAM but the loss is largely reversed because tokens are 16-bit, not 32. And 16-bit tokens are faster to fetch, so the performance implications are significant.
It was arbitrary to suggest four as the number of shifts -- and it makes my scheme reminiscent of x86 real-mode addressing. But I'm not advocating segmentation (and the necessary use of two registers); instead there'd be one, 32-bit IP register inside the core. The wrinkle is that, when it loads from memory, the ms 12 bits and the ls 4 bits of the IP register load as zeros.
Four was an arbitrary choice, and other shift values bear consideration. Some scenarios would benefit best from a one-bit shift, or perhaps three. So that's a matter for debate. Or...
The necessity to define the shift (to have it "cast in stone") can be avoided if the shift is determined by a configuration register. (Yes a creeping feature but it needn't be over the top. Maybe allow only two options, say 0- or 4-bit shifting, if the core size is constrained. A fancier core would have a fancier configuration register, and offer, say, 0-, 2-, 4- or 6-bit shifting... ) Anyway I'd hesitate to blow the token size up to 32 bits.
Obviously the Forth compiler -- assuming the user will want one -- needs alterations to deal with this scheme. That's doable, as I know from making similar alterations. At issue was the compiler for another hybrid Forth with 32-bit cells & operations but 16-bit ITC tokens. The tokens aren't
scaled, but you do have to add a fixed offset to find the start of the 64K dictionary within the flat 32-bit address space. (Actually it's a flat
20-bit address space, improbably accomplished with real-mode x86 under DOS.
Edit: raise the compiler issue, last paragraph
