It is currently Sun Nov 24, 2024 6:35 pm
 Post subject: OT: Forth haikus
PostPosted: Tue Oct 21, 2014 1:25 pm
To be treated, perhaps, as an educational resource:
http://forthsalon.appspot.com/
See also
http://repl.it/languages/Forth
where you can run Forth in your browser, and share your code too.
 Post subject: Re: OT: Forth haikus
PostPosted: Tue Oct 21, 2014 1:39 pm
Unfortunately, I see:
Unsupported Browser
Unfortunately, this site requires a browser that supports the <canvas> tag and Javascript.
You will need to install one of these browsers to use this site:
Google Chrome
Firefox
Safari
Which prompts me to compose the following:
Unsupported User
Unfortunately, this user requires a web site that supports alternative browsers, such as Opera.
You will need to write standards-compliant web code to interest this user.
World Wide Web Consortium
AnyBrowser.org
PostPosted: Tue Oct 21, 2014 1:40 pm
That is unfortunate. Does it apply to both?
PostPosted: Tue Oct 21, 2014 2:56 pm
Oh, sorry, it only applies to the forthsalon.appspot.com page. The repl.it page works fine.
PostPosted: Tue Oct 21, 2014 3:08 pm
Here's a haiku for them.
"Browse with only this,
all else will be rejected."
The concept is missed.
PostPosted: Tue Oct 21, 2014 3:10 pm
For info, from the "about" page of the haiku site:
A Forth Haiku is an attempt to mix mathematics, art, and the Forth programming language. It resembles a texture shader, however, the emphasis is on direct expression in the resulting image.
The Forth program describing each Haiku is run once per pixel over a square image. Forth cells are floating point. Conditions return 1 instead of -1. The position is available from the words x and y, which range from 0 to 1, which the origin in the lower left hand corner. The haiku returns the desired color in (red, green, blue, alpha), with alpha being topmost on the stack. If the stack has less than 4 items default values are assumed: red:0, green:0, blue:0, alpha:1.
A sample program, called "Disco:"
x 9.4 * sin
y 9.4 * sin
t 4 * sin
dup t 2 * sin *
dup t 3 * sin *
