It is currently Tue May 14, 2024 11:46 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Mon Apr 07, 2014 6:55 am
Ah yes, I see that now in my printed ANS 1994 version. Memory still holds strings as counted, not null-terminated, but they prefer that string functions put c-addr u on the stack. Older Forths did have COUNT which I defined in my '816 Forth as
        HEADER "COUNT", NOT_IMMEDIATE   ; ( ADR -- ADR+1 LEN )
COUNT:  PRIMITIVE
        LDA    (0,X)
        AND    #$00FF
        INC    0,X
        JMP    PUSH
It could be defined in Forth on a 6502/816 as
: COUNT   DUP 1+ SWAP C@  ;     ( adr1 -- adr2 u )
which is not only slower but takes more memory than the '816 primitive above.
My HP-71 hand-held computer's Forth in the Forth/Assembler module usually represents a string as c_addr u, and it seems to mostly be Forth-79; so it's strange that Forth-83 did a step back, and then ANS went to c_addr u again. The single cell on the stack is nevertheless nice sometimes though, just to reduce stack operations.
PostPosted: Mon Apr 07, 2014 2:18 pm
The method that you describe covers how strings are represented on the stack for use, but not how they are stored. I am thinking about implementing a format that allows packed or unpacked to co-exist peacefully (I hope):
The first word of the stored string is the key. If the most-significant 8-bits are zero, then it's an unpacked string up to 2^24-1 chars long, with one char per word.
If the most-significant 8-bits of the first word are non-zero, then it's a packed string up to 255 chars long, with up to four chars per word.
An alternate 'storage' format could use a different technique to save space, but I'm not worried about that yet.
Mike
PostPosted: Mon Apr 07, 2014 5:16 pm
For most packed strings those MS 8-bits will automatically assume a non-zero value. But I guess you know very short packed strings will need special attention. If the string is only, say, 2 characters, remember to explicitly write a non-zero value into those MS 8-bits. :wink:
PostPosted: Mon Apr 07, 2014 6:34 pm
I'm no Forth wiz (don't even know how to use Forth) but has anyone considered the idea of 2-for-3 string encoding? Said encoding relies on the fact that if case-insensitivity is acceptable, only five bits are required to represent all of the characters of the Roman alphabet, which means three ASCII characters can be compressed to two bytes. I use that principle in my 65C816 monitor to encode the mnemonics into a smaller space (e.g., LDA becomes $115a). The basic method can be theoretically extended to any string size, as long as the maximum unencoded string length is an exact multiple of 3. Eight bit 6502 code that runs in the Kowalski simulator follows.
   .opt proc6502,caseinsensitive
;PACK 65xx ASCII MNEMONIC INTO 2 BYTE BINARY
packmne  =$80                  ;packed mnemonic storage
basechar =$3f                  ;conversion constant
n_shift  =5                    ;bits per packed char
s_mnemon =3                    ;size of a 65xx mnemonic
ucmask   =@01011111            ;upper case conversion mask
         *=$2000
         ldx #0
         stx packmne           ;initialize
         stx packmne+1
l001     lda mnemon,x          ;get char
         and #ucmask           ;change to UC
         sec
         sbc #basechar         ;change to binary
         ldy #n_shift
l002     lsr
         ror packmne+1
         ror packmne
         dey
         bne l002
         inx
         cpx #s_mnemon
         bne l001              ;next char
         brk
mnemon   .byte "lda"           ;test mnemonic
   .end
PostPosted: Mon Apr 07, 2014 6:49 pm
The problem is, so many strings require special characters.
Another possibility is radix-36 encoding, which if I recall correctly DEC used at one time in the PDP-11 family. Actually you can go up to radix-40 to encode 3 characters into 16 bits, which gives you letters, digits, and four other characters.
Edited to add: my mistake, DEC used radix-40 on the PDP-11. Though they called it radix-50 (octal). http://en.wikipedia.org/wiki/DEC_Radix-50
PostPosted: Tue Apr 08, 2014 1:53 am
I'm thinking about something like the following:
string: 65m32
packed: 0536356d 3332xxxx
unpacked: 00000005 00000036 00000035 0000006d 00000033 00000032
empty string:
packed: 00000000
unpacked: 00000000
string containing a single NUL:
packed: 0100xxxx
unpacked: 00000001 00000000
Mike
PostPosted: Tue Apr 08, 2014 4:49 am
I'm no Forth wiz (don't even know how to use Forth) but has anyone considered the idea of 2-for-3 string encoding? Said encoding relies on the fact that if case-insensitivity is acceptable, only five bits are required to represent all of the characters of the Roman alphabet, which means three ASCII characters can be compressed to two bytes...
That method is quite efficient for the use that you specified, but not a good general-purpose solution. I think that Woz did something similar back in 1977 for the 'L' command in his Apple ][ monitor ROM ... maybe even a bit more aggressive than that, but I don't remember for sure.
Mike
PostPosted: Wed Apr 09, 2014 5:22 am
It seems to me that a few of us are implementing a Forth for 65xxCPUs, with different design goals in mind. I don't mean to hijack this thread, and I also don't know whether it's right to start a new thread for every design issue that comes up. But the ugly has to go somewhere, so here goes:
In my implementation (for 6502), the innermost DO LOOP counter and limit are stored in 4 bytes of zeropage. This is for the speed and size advantages of not having to twiddle the machine stack all day long. As I'm reimplementing NUMBER, it occurs to me that I can also use >R R@ R> pretty freely inside the body of an inner DO loop, without having to worry about the loop index I getting in the way. It's not 79, 83, ANS, or Fig to be able to write something where R@ and I are not synonymous, like this, but it would work! Would I still be able to include the word FORTH-83 in my dictionary, which doesn't seem to have a lot to say about this divergence between R@ and I ?
( There is a string that is probably a number stored from addrlow..addrhigh -- caveat -- this probably has some bugs )
: NUMBER  ( addr -- d ; convert a counted string to a signed double, keeping track of the decimal )
   0 0 ROT COUNT   ( 0 0 addr+1 len )
   OVER C@ [ ASCII - ] =   ( leading minus? )
   DUP >R  IF  1- SWAP 1+ SWAP  THEN
   OVER + 1+ SWAP   ( 0 0 addrhigh addrlow )
   DPL ON
   ?DO
      BASE @ >R
      I C@  R@  DIGIT   ( doublesubtotal (currdigit) flag )
      IF
         SWAP R@ UM*
         DROP ROT
         R@ UM* D+
         DPL @ 1+  IF  DPL 1+!  THEN
      ELSE
         I C@ [ ASCII . ] =
         DPL @ 0<  AND
         IF
            DPL OFF
         ELSE
            3 FAIL ( performs "NOT FOUND" ABORT - do not pass go do not collect $200 )
         THEN
      THEN
      R> DROP
   LOOP
   R>  IF  DNEGATE  THEN ;
Another thing I'm considering is to dispense with VOCABULARY entirely, at least in the initial release of PETTIL. No CURRENT, no CONTEXT, no VOCABULARY, but there would be a LATEST. Otherwise doing FORGET CREATE FIND all becomes mind-boggling, at least for my easily boggled mind. This is an obvious dealbreaker for the standards committee who will no doubt judge me harshly and kick me out of their clubhouse until I fix it. While I'm at it, I'm probably going to be playing fast and loose with BLOCK, EMPTY-BUFFERS, SAVE-BUFFERS, and all of that too, because this is not 1970 and I am not Chuck Moore and there is already a nice filesystem available on my target hardware platform, so I plan to use it. I will say that I am enjoying this project more than I really ought to, particularly the code golf. It's just that doing these things that violate standards makes me feel so impure. OB6502: Here's 1+! which I'm proud of, a word from the Forth79 Referrence wordset
;       1+!   ( n -- )
; increments the word addressed by n
oneplusstorelfa .byt $de,$ad ; link
                .byt (oneplusstore-*-1)|bit7 ; length
                .asc "1+","!"|bit7 ; name
; there is no CFA, there is only code
oneplusstore    ldy #$ff
                sec
oneplusstore01  iny
                lda (tos),y
                adc #0 ; add one the first time, add C the second time
                sta (tos),y
                tya ; to set the Z flag
                beq oneplusstore01 ; loop exactly twice
                jmp pops
PostPosted: Wed Apr 09, 2014 6:12 am
One important thing is to be able to find stuff again later. Sometimes it helps to keep related things together even as a topic evolves, and other times it's good to separate it out and give it its own topic. The original poster's feelings on it should be respected, if he expresses or implies any.
It would probably be good then to push the ZP bytes before starting another loop, so you can nest loops. Actually, the standard word J reaches out to get the index value of the next loop out.
That's what I did. The volcabularies are particularly useful for when the main Forth and the assembler share word names, like AND; but in my assembler, I put the addressing mode on as part of the name, so there's no conflict anyway, like AND_ABS, AND#, AND_ZP, etc.. It made it possible to write the assembler in an evening and make it use the normal mnemonic-operand order, without having to do any parsing. (You just have to comma-in the operands, like LDA# 41 C, )
I used blocks briefly in about 1990 and absolutely hated them. I won't say they don't have any advantages, but I will say the disadvantages outweigh the advantages. I use a nice professional programmer's text editor, and can mark a block to try instantly, without leaving the editor. I don't have to work in a teensy window with a decrepit block editor.
1+! was called INCR by at least one commercial Forth supplier, so that's what I called mine. Here it is in my '816 Forth, along with the accompanying DECR:
        HEADER "INCR", NOT_IMMEDIATE    ; ( addr -- )
INCR:   PRIMITIVE
        LDA     (0,X)           ; Unfortunately there's no INC (DP,X)
        INA                     ; instruction.
 incr1: STA     (0,X)           ; This word probably won't get used enough to
        JMP     POP             ; justify using the POP1 macro here.)
        HEADER "DECR", NOT_IMMEDIATE    ; ( addr -- )
DECR:   PRIMITIVE
        LDA     (0,X)           ; Unfortunately, there's no DEC (DP,X)
        DEA                     ; instruction.
        BRA     incr1           ; Branch into INCR 's body.
With a few different projects going on here, it's hard to remember who's doing what; but in ITC Forth, the CFA of a primitive just points to the address after the CFA which is where the assembly-language code is-- in the parameter field, just to confuse things. :lol:
I haven't taken the time to look at the details of your NUMBER code (I really must get back to work!), but one thing I saw immediately was the first ) in "( doublesubtotal (currdigit) flag )" which would make Forth look up "flag". If you use \ (the backslash) for comments, you can put anything you want after it, including )...), since the entire remainder of the line will be ignored. Another usage example would be if you have f(1)-f(2) in the comments. Another one that popped out is that in the line " OVER C@ [ ASCII - ] = ( leading minus? )", you need LITERAL after the ] so the result will get compiled. Since [...] LITERAL is so common, I defined a word ]LIT to shorten it up.
PostPosted: Wed Apr 09, 2014 1:43 pm
A few comments:
R@ and I have been different for a long time. Take a look at F83's implementation of DO..LOOP (or CamelForth's, which shamelessly adopted the same technique).
You can do non-standard things in your kernel, as long as they're implementing standard functions. Your definition of NUMBER, for example, takes advantage of the fact that the innermost loop index I is kept in a register, so >R won't interfere with it. Of course, your NUMBER probably won't work in any other ANS Forth. And application programs can't use that trick and remain portable.
FORGET has largely been deprecated. Implement ANS Forth's MARKER instead. It's easier to implement and more versatile (e.g. it can easily handle separate Program and Data dictionary pointers).
PostPosted: Sat Apr 12, 2014 2:49 pm
This would be extremely useful for compressing some text for cartoon speech bubbles, which I could limit to A-Z 0-9 and (say) space, comma, dash, question. It's a PET in graphics mode so I don't need upper/lowercase.
The trick is, how do you do unpack it quickly? Setup and two calls to UM/MOD would be a lot of overhead. Is there a quick divide-by-5 algorithm for 6502? I googled and the best I could come up with is a 7/32 (0.21875) or 13/64 (0.203125) approximation approach.
PostPosted: Sat Apr 12, 2014 3:03 pm
Given that you're limited to byte operations, I'm not sure this would be much faster than an ordinary 16-by-8 bit division, but here you go:
Integer division by constants
http://blogs.msdn.com/b/devdev/archive/ ... 02980.aspx
    q = (x >> 3) + (x >> 4);
    q = q + (q >> 4);
    q = q + (q >> 8);
    q = q + (q >> 16);
    r = x - 5*q;
    return q + ((11*r) >> 5);
Another useful approximation is 51/256 = 0.19922.
PostPosted: Mon Aug 04, 2014 10:26 pm
Nice idea to allow the strings to start non-justified - but to keep the benefit of allowing any character in a counted-string implementation, there's no room for special values. So as Garth says, you need to find 2 bits for this.
Yikes! I was distracted by 100 other things when Garth offered me that wise bit of advice, and now I'm facing that exact conundrum. I think that my revised design will have to steal two more bits from the first word, which would then leave my maximum unpacked string length reduced to 2^22 - 1, while leaving the maximum packed length at 255.
It's either that, or a separate set of words for each type (SKIP/SKIPP, SCAN/SCANP, etc.) and I'm not convinced that it would be a good idea to open that potential can of worms.
Perhaps my initial implementation of Camel Forth will only support unpacked strings, and I'll just write custom primitive versions of FIND and friends to save space just in my Headers. Yeah, that's probably what I'll do ... that (and the double-cell math family) should be enough to provide me enough info to finally put the final touches on my machine instruction set.
Mike
