It is currently Fri Nov 22, 2024 11:29 pm
PostPosted: Sun Jul 14, 2013 4:26 pm
In my quest to make my FPGA Playground board useful (Arlet's core and 64K SRAM, serial IO) I thought Forth would be a good next step (I have Daryl's 1K monitor running as a loader and can load binaries from my linux box).
So where can I find a simple Forth to start with? I've written many Forth-like systems and don't really feel like doing one right now (too many pots in the fire). I figured there would be something at 6502.org resources or code but could not find anything other than the old FIG listing.
Daryl mentioned in some thread that he fixed FIG to work on his boards. Any chance of a copy?
Anyone have a minimal implementation?
PostPosted: Sun Jul 14, 2013 5:10 pm
The latest version I have is with my AVR65C02 Emulator. If you download the source files, in the SBC2OS folder, you will find the FIGForth.asm source file. Just adjust your memory boundaries and IO and it should work.
Will follow up tomorrow.
PostPosted: Mon Jul 15, 2013 12:02 am
This is as basic a Fig Forth as you can get as well.
https://dl.dropboxusercontent.com/u/334 ... IG6502.ASM
It works, I think it has the U/ fix in it.
Super simple assembly.
PostPosted: Mon Jul 15, 2013 4:34 am
Sadly, I have tried 3 varieties of FigForth (Daryl's, whartung's link and another one from someone else's SBC site), and they all silently die. I traced it up to the first NEXT (not really traced, just stuck rts's in), after that it gets harder to debug... I will have to make some fixes to Daryl's monitor (the register display command does not work as is) to investigate it more properly. I sure hope it's something easy!
What does Fig Forth display on the screen on a successful start?
PostPosted: Mon Jul 15, 2013 6:20 am
Try using a BRK vs the RTS, that will capture the register values.
This is the FigFORTH prompt:
fig-FORTH 1.0
After pressing enter, you get:
OK
To edit my source (From the AVR65C02 files:)
Fix these:
ORIG = $0400 ; origin of FORTH's Dictionary. (good as is)
MEM = $3F00 ; top of assigned memory+1 byte. (adjust for your RAM)
; Monitor calls for terminal support
OUTCH = output ; output one ASCII char. to term.
INCH = Input_chr ; input one ASCII char. to term.
TCR = Print_CR ; terminal return and line feed.
* = $0400 ; add this if you haven't defined it anywhere else
ENTER NOP ; Vector to COLD entry (good as is - included for reference)
MON .WORD *+2 ; (good as is - just included for reference)
JMP MonitorBoot ; back to SBC Monitor
That should be all you need to do to get it running.
PostPosted: Mon Jul 15, 2013 4:20 pm
Daryl, thanks for the brk tip.
The changes I made are exactly what you suggest. Another place I had to bypass was XQTER:
;         XQTER leaves a boolean representing terminal break
XQTER          ;jsr   cbrk              ;if Ctrl-c, set C else clear C
                clc                     ;TODO: for now
                lda   #$00              ;0
                rol   a                 ;move carry to bit 0
                jmp   PUSHOA
This should behave as no Ctrl-c ever takes place for now...
EDIT: I found one problem with my conversion code that messed up the initial load of address of ABORT into IP (did not insert #)... But something else is still wrong... Got the prompt after fixing another (my own) bug, crashing on literal... Getting closer though
PostPosted: Mon Jul 15, 2013 5:58 pm
In my code, there's a line "JSR TRAC" in NEXT (I think), there's some code commented out above it (an attempt to make TRACING settable with a user variable, that I never managed to get to work).
If you uncomment that JSR, it will show you running through the high level words.
But, you must have something fundamentally wrong going on, the basic interpreter should certainly work.
PostPosted: Mon Jul 15, 2013 6:15 pm
Daryl, the problem was the 3 equates for the IO routines. I changed the code to call the routines directly and got to the prompt anyway.
It almost works... The prompt comes up, I hit CR, "OK" comes up. Typing in literals crashes it, . crashes it, DUP returns "DUP ?" and then crashes...
EDIT: it's just flaky. Hitting CR a few times will crash.
I probably have to debug the outer loop to find the problem
PostPosted: Mon Jul 15, 2013 8:52 pm
That's really odd.
Since you're not actually doing anything to it, beyond swapping out a couple of I/O routines, it should Just Work(tm). The core of the system is just a couple of machine code words, and the inner interpreter (i.e. NEXT). Assuming all of that is stable, you shouldn't have any problems.
This is on real hardware, yes? I had lots of issues with my Forth, but that's because it was running on my simulator and I was using it as a test mule to help prove it. In the end I didn't have to change any actual code.
So I'm just surprised you're having all of these issues getting the prompt up and simple words and definitions working. (Disk I/O is another matter, but even that isn't too bad.)
PostPosted: Mon Jul 15, 2013 11:31 pm
Real hardware is a relative term - it's an FPGA with Arlet's core and 64K SRAM running at 45MHz. Real enough, anyway.
Daryl's monitor is running solid as a rock, but out of an internal 2K BRAM, so it is possible that there is some SRAM-related instability (45 was the upper limit in previous tests). I will try dropping the clock first.
PostPosted: Tue Jul 16, 2013 12:26 am
Yes, it was unstable due to high speed. It is running solidly so far at 30MHz. I am so happy to have Fig-Forth running after all these years :lol:
Thank you!
PostPosted: Tue Jul 16, 2013 12:32 am
Where's the "Like" button? I need it once in a while.
Do make sure you incorporate the division and multiplication bug fixes.
PostPosted: Tue Jul 16, 2013 12:44 am
Thanks Garth!
I believe that Daryl had incorporated your math bugfixes. I had to make a minor fix to replace an stz. [EDIT: removed silly question]. I do miss the 65C02 instructions.
PostPosted: Tue Jul 16, 2013 3:39 am
It is working at 40MHz now (I moved the circuit around a little to speed it up). I have to do some catching up as I haven't used Forth in a while (I've been using my own forth-like systems over the years). I feel like I found an old friend!
