It is currently Thu Nov 21, 2024 1:21 pm
PostPosted: Fri Feb 26, 2021 11:58 pm
In another thread I brought up the idea of using screens for data storage. Here is one of those ideas.
I have trouble remembering what kind of data is required when entering a word definition and what data is present on the data stack on exit of a word definition. I am sure that most peoples desktop are plastered with notes for remembering such requirements. I like to be able to find the answer without searching through all my notes. This is what I came up with.
The way this works is just type "HELP word" and the word is returned with its requirements like so:
Colons are used as the delimiters.
HELP ENCLOSE ( this is typed )
:ENCLOSE ( addr1 c -- addr1 n1 n2 cnt ) : ( this is returned with colons as delimiters )
( Scrn #10 )
0 ( word matching )
1 : ?stack2 ( -- f ) sp@ csp @ 2- swap u< ;
2 : postpone [compile] [compile] ; immediate
3 : [char] bl word here 1+ c@ postpone literal ; immediate
4 11 constant firsthelp ( set the first screen of help data here )
5 0 variable tscr 0 variable lasthelp
6 : inithlp dr1 ?stack2 if firsthelp then tscr ! tscr @ 5 +
7 lasthelp ! ;
8 : disp dup [char] : enclose >R drop drop R> type ;
9 : match ( addr -- f ) here 1+ here c@ rot swap -dup if over +
A swap do dup c@ i c@ - if 0= leave else 1+ then loop else drop
B drop 0 then ;
C : help inithlp bl word begin 0 tscr @ (line) drop dup
D b/buf + swap do i c@ [char] : = if i 1+ match if i disp drop
E quit then then loop tscr inc lasthelp @ = until ;
F ( notes: b/buf is bytes per buffer )
( note: make firsthelp the starting screen# the below words start at )
( notes: I=Immediate, C=Compile only, U=User variable, E=Execution only )
( c=character, n=number, d=dbl number, u=unsigned number, addr=address, cnt=count, rem=remainder, quot=quotient, prod=product, b=byte )
( Scrn #11 )
:! ( n addr -- ) :!csp ( -- ) :# ( d1 -- d2 ) :#> ( d -- addr cnt ) :#S ( d1 -- d2 ) :' ( -- addr ) :( ( -- ) :(.") ( -C- ) :(;code) ( -C- ) :(+loop) ( n -C- ) :(abort) ( -- ) :(do) ( -C- ) :(find) ( addr1 addr2 -- pfa len tf ) :(line) ( n1 n2 -- addr cnt ) :(loop) ( -C-) :(number) ( d1 addr1 -- d2 addr2 ) :* ( n1 n2 -- prod ) :*/ ( n1 n2 n3 -- n4 ) :*/mod ( n1 n2 n3 -- rem quot ) :+ ( n1 n2 -- sum ) :+! ( n addr -- ) :+- ( n1 n2 -- n3 ) :+buf ( addr -- addr2 flag ) :+loop ( n1 -E- )( addr n2 -- ) :+origin ( n -- addr ) :, ( n -- ) :- ( n1 n2 -- dif ) :--> ( -I- ) :-dup ( n1 -0- n1 ) ( n1 -- n1 n1 ) :-find ( -- pfa len tf ) ( -- ff ) :-trailing ( addr n1 -- addr n2 ) :. ( n -- ) :." ( -I- ) :.line ( line scr -- ) :.R ( n1 n2 -- ) :/ ( n1 n2 -- quot ) :/mod ( n1 n2 -- rem quot ) :0< ( n -- flag ) :0= ( n -- flag ) :0branch ( flag -C- ) :1+ ( n1 -- n2 ) :2+ ( n1 -- n2 ) :: ( -PE- ) :; ( -IC) :;code ( -IC- ) :;S ( -I- ) :< (n1 n2 -- flag ) :<# ( -- ) :<builds ( -C- ) := ( n1 n2 -- flag ) :> ( n1 n2 -- flag ) :>R ( n -C- ) :? ( addr -- ) :?comp ( -- ) :?csp ( -- ) :?error ( flag n -- ) :?exec ( -- ) :?loading ( -- ) :?pairs ( n1 n2 -- ) :?stack ( -- ) :?terminal ( -- flag ) :@ ( addr -- n ) :abort ( -- ) :abs ( n -- u ) :again ( addr n -IC- ) :allot ( n -- ) :and ( n1 n2 -- n3 ) :b/buf ( -- n ) :b/scr ( -- n ) :back ( addr -- ) :base ( -U- addr ) :begin ( -IC- addr ) :bl ( -- c ) :blanks ( addr cnt -- ) :blk ( -U- addr ) :block ( n -- addr ) :branch ( -C- ) :buffer ( n -- addr ) :c! ( b addr -- ) :c, ( b -- ) :c@ ( addr -- b ) :cfa ( pfa -- cfa ) :cmove ( from to cnt -- ) :cold ( -- ) :compile ( -C- ) :constant ( n -- ) :context ( -U- addr ) :cr ( -- ) :create ( -- ) :csp ( -U- addr ) :d+ ( d1 d2 -- dsum ) :d+- ( d1 n -- d2 ) :d. ( d -- ) :d.r ( d n -- ) :dabs ( d -- ud ) :decimal ( -- ) :definitions ( -- ) :digit ( c n1 -- n2 tf ) ( c n1 -- ff ) :dlist ( -- ) :dliteral ( d -E- d ) ( d -- ) :dminus ( d1 -- d2 ) :do ( n1 n2 -E- ) ( addr n -IC- ) :does> ( -- ) :dp ( -U- addr ) :dpl ( -U- addr ) :dr0 ( -- ) :dr! ( n -- ) :drop ( n -- ) :dump ( addr n -- ) :dup ( n -- n n ) :else ( addr1 n1 -IC- addr2 n2 ) :emit ( c -- ) :empty-buffers ( -- ) :enclose ( addr1 c -- addr1 n1 n2 cnt ) :end ( -IC- ) :endif ( addr n -IC- ) :erase ( addr n -- ) :error ( line -- in blk ) :execute ( addr - ) :expect ( addr cnt -- ) :fence ( -U- addr ) :fill ( addr cnt b -- ) :first ( -- n ) :fld ( -U- addr ) :forget ( -E- ) :forth ( -I-) :here ( -- addr ) :hex ( -- ) :hld ( -- addr ) :hold ( c -- ) :I ( -C- n ) :id. ( addr -- ) :if ( flag -E- ) ( -IC- addr n ) :immediate ( -- ) :in ( -U- addr ) :index ( from -- ) :interpret ( -- ) :key ( -- c ) :latest ( -- addr ) :leave ( -C- ) :lfa ( pfa -- lfa ) :limit ( -- n ) :list ( n -- ) :lit ( -C- n ) :literal ( n -IC- ) :load ( n -- ) :loop ( addr n -IC- ) :m* ( n1 n2 -- d ) :m/ ( d n1 -- rem quot ) :m/mod ( ud1 u2 -- rem dquot ) :max ( n1 n2 -- max ) :message ( n -- ) :min ( n1 n2 -- min ) :minus ( n1 -- n2 ) :mod ( n1 n2 -- mod ) :mon ( -- ) :move ( addr1 addr2 cnt -- ) :nfa ( pfa -- nfa ) :number ( addr -- d ) ( addr points to an ascii based number prefixed by length and terminated with a space ) :offset ( -U- addr ) :or ( n1 n2 -- n3 ) :out ( -U- addr ) :over ( n1 n2 -- n1 n2 n1 ) :pad ( -- addr ) :pfa ( nfa -- pfa ) :prev ( -U- addr ) :query ( -- ) :quit ( -- ) :R ( -- n ) :R# ( -U- addr ) :R/W ( addr blk flag -- ) :R> ( -- n ) :R0 ( -U- addr ) :repeat ( addr n -IC- ) :rot ( n1 n2 n3 -- n2 n3 n1 ) :rp! ( -- ) :s->d ( n -- d ) :s0 ( -U- addr ) :scr ( -U- addr ) :sign ( n d -- d ) :smudge ( -- ) :sp! ( -- ) :sp@ ( -- addr ) :space ( -- ) :spaces ( n -- ) :state ( -U- addr ) :swap ( n1 n2 -- n2 n1 ) :then ( -IC- ) :tib ( -U- addr ) :toggle ( addr b -- ) :traverse ( addr1 n -- addr2 ) :type ( addr cnt -- ) :u* ( u1 u2 -- ud ) :u/ ( u1 u2 -- urem uquot ) :u< ( u1 u2 -- flag ) :until ( flag -E- ) ( addr n -IC- ) :update ( -- ) :use ( -- addr ) :user ( n -- ) :variable ( n variable word ) :voc-link ( -U- addr ) :vocabulary ( -E- ) :warning ( -U- addr ) :while ( flag -E- ) ( addr1 n1 -C- addr 1 n1 addr2 n2 ) :width ( -U- addr ) :word ( c -- ) :xor ( n1 n2 -- xor ) :[ ( -I- ) :[compile] ( -I- ) :
PostPosted: Sat Feb 27, 2021 6:19 am
Ha! Totally forgot about some colon combinations getting converted to smiley emoji's.when the text was posted to the forum.
What to do? What to do?
PostPosted: Sat Feb 27, 2021 7:56 am
Just click "Edit" under the post, at the right side, and then check the "Disable smilies" box below the area where you write or edit the post.
PostPosted: Sat Feb 27, 2021 4:36 pm
Thanks! The computer that has my emulator for Forth uses an outdated web browser and doesn't have the EDIT button. Didn't see it right away.
