It is currently Sat Nov 23, 2024 9:29 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jul 08, 2020 4:03 am
So, one trick with WIDTH is to create hexadecimal-literal words $xx and $xxxx with WIDTH set to 1. They'd be IMMEDIATE, and parse their text after the first character as a hexadecimal literal. I forget where I came across this trick, and I don't believe I ever used it.
PostPosted: Wed Jul 08, 2020 8:35 pm
I've never tried this and Fleet Forth does not have WIDTH , but it does set the high bit of the count and the high bit of the last character in the name ( to keep (FIND) fast ) so the following would accomplish the same thing in Fleet Forth:
: $  ( -- N )
   BASE @ >R HEX HERE 1+ -NUMBER R> BASE ! ?HUH
   DROP STATE @ 0EXIT [COMPILE] LITERAL ; IMMEDIATE
// GIVE $ A COUNT OF 3
LATEST 2 TOGGLE
: $  ( -- N )
   [COMPILE] $XX ; IMMEDIATE
// GIVE THIS $ A COUNT OF 5
LATEST 4 TOGGLE
Since this is for a Commodore 64, just read each double forward slash as a backslash.
PostPosted: Sat Sep 19, 2020 3:09 am
I've been playing around with Fig Forth and one thing mystifies me. I can't see how it initializes the X register for the argument stack. Does it just use page zero as a circular buffer and starts with whatever X value has originally? Or does it somehow stealth initializes it?
PostPosted: Sat Sep 19, 2020 3:16 am
It's initialized in SP! (at $5E8) which is called from ABORT (which is at $121D).
PostPosted: Sat Sep 19, 2020 2:17 pm
Thanks. I was looking for an ldx instructions, but I see how it's done now.
PostPosted: Mon Jan 18, 2021 8:06 pm
Here is a slight speed improvement for CMOVE
From this
   LDA #3
   JSR SETUP
L370   CPY N
   BNE L375
   DEC N+1
   BPL L375
   JMP NEXT
L375   LDA (N+4),Y
   STA (N+2),Y
   INY
   BNE L370
   INC N+5
   INC N+3
   JMP L370
To this
   LDA #3
   JSR SETUP   ; Y-reg returns with zero
L370   CPY N
   BEQ L380
L375   LDA (N+4),Y
   STA (N+2),Y
   INY
   BNE L370
   INC N+3
   INC N+5
   BNE L370      ; always
L380   DEC N+1
   BPL L375
   JMP NEXT
PostPosted: Mon Jan 18, 2021 8:58 pm
Since CMOVE and CMOVE> are usually used for segments of less than a page, I wrote words QCMOVE (for "quick CMOVE) and QCMOVE> to be faster. Here's QCMOVE:
     JSR  QSETUP       ; Put "TO" addr in N, and "FROM" addr in N+2)
     LDY  #0
 2$: TYA
     CMP  0,X
     BEQ  1$
     LDA  (N+2),Y
     STA  (N),Y
     INY
     BRA  2$
 1$: JMP  POP3
where QSETUP is:
QSETUP: LDA  2,X
        STA  N
        LDA  3,X
        STA  N+1
        LDA  4,X
        STA  N+2
        LDA  5,X
        STA  N+3
        RTS
(which is used by other things as well, and doesn't do the looping and testing like SETUP does).
Here's QCMOVE>:
     LDY  0,X
 2$: DEY
     CPY  #$FF
     BEQ  1$
     LDA  (N+2),Y
     STA  (N),Y
     BRA  2$
 1$: JMP  POP3
Hopefully I copied it correctly from a less-readable form.
PostPosted: Mon Jan 18, 2021 10:48 pm
I had broken the code, but nobody complained. Shows the fix with indented lines.
IamRob wrote:
For a slightly quicker method, but a few more bytes, this could be done.
QSETUP:
      CLC
   LDA  2,X
      ADC 0,X   ; add count
   STA  N
   LDY  3,X
   DEY      ; note hi-bytes are decremented
   STY  N+1
   LDA  4,X
      ADC #0
   STA  N+2
   LDY  5,X
   STY  N+3
   RTS
     JSR QSETUP
     LDA 0,X
     EOR #$FF      ; reverse count to count up to 0
     TAY
      INY      ; count correction due to EOR
]LP LDA  (N+2),Y
     STA  (N),Y
     INY
     BNE  ]LP
     JMP  POP3
PostPosted: Tue Jan 19, 2021 12:03 am
ProForth, which is based on FigForth but is fully compatible with the '79 standard, and I have also added some '83 standard words, for some further enhanced compatibility.
One of the changes I have made that doesn't seem to have broken any compatibility with FigForth, is to have -FIND return with the CFA instead of the PFA.
Steps to do that are:
' (find) 36 dup c@ ( it is decimal 36 ($24)( make sure it says 5)( do a memory DUMP if not showing the 5 and adjust the 36)
' (find) 36 dup + 3 swap c! ; ( change it to 3)
once you do that you can now see that (find) has changed to the CFA and requires 36 2+
' (find) 38 dup c@
next change these definitions from
: cfa pfa 2 - ;
: lfa pfa 4 - ;
: nfa pfa 5 - -1 traverse ;
: pfa traverse 5 + ;
to
: cfa ; ( make this into a NULL word)
: lfa 4 - ;
: nfa 3 - -1 traverse
: pfa 1 traverse 5 + ;
or
: pfa dup @ 1f and + 5 + ;
INTERPRET has two occurrences of CFA that are no longer needed, but since the CFA word above was made into a NULL word, they have no effect.
Make sure you are saving this on a backup of the Forth System.
At this point, the only word that is broken after all the changes is (;CODE). (;CODE) has PFA CFA, but since CFA is now a NUL word, the CFA word cannot be used. A couple of options: one is to make 2- a word definition higher up in memory and manually link to it or since (;CODE) is so short, just make a new definition for it:
: (;CODE) ( --- ) R> LATEST PFA 2 - ! ;
At this point, nothing is broken and we are now closer to being able to use new words that are supported by newer standards which were created to aid in Forth compatibility across platforms.
words that can now be used are
: >body 2+ ;
