It is currently Tue Jun 04, 2024 11:14 pm
PostPosted: Mon May 11, 2015 7:21 am
I was about to post this over in Charlie's split-stack thread, but I already felt a bit guilty for contributing to thread drift over there, so I figured that it was best to start a new one (on which to drift around).
Awhile ago, Anton Ertl seemed to have modified Gforth's NEXT to trace and study the execution frequencies of primitives and combinations of primitives in preparation for trying to implement something he called a "pin-hole optimizer".
More details are here:
i drop and - ended up lower on the list than I expected, but I'm not a Forth programmer, so my expectations should be taken with a grain of salt. It also seems that programming style doesn't really become much of a factor until the sequence var: @ appears, outside the top 10.
These data are derived from dynamic traces of real applications running on Gforth,
   not from small benchmarks that might provide unrealistic results:
cross
   is a Forth cross compiler written mainly by Bernd Paysan.
   Length 5,779,740 primitives.
gs
   is a data and control flow analysis program written by Anton Ertl.
   It uses locals a lot. Length 3,540,682 primitives.
prims2x
   is a filter that converts primitives specifications into C code.
   Anton Ertl wrote most of it. Length 5,822,924 primitives.
(Here, Anton uses the term "primitive" for anything that performs a NEXT or NEXT1;
   this includes routines like docol and dovar).
  Total        cross         gs       prims2x
15143346    5779740    3540682    5822924   NEXTS
 2038446     793119     442464     802863   ;s
 1995025     787457     428114     779454   col:
 1355759     503162     283813     568784   @
  765602     275772     183685     306145   ?branch
  700996     246049     141642     313305   lit
  674069     270409     125561     278099   col: col:
  519952     151876      36627     331449   var:
  515649     208841     126882     179926   dup
  486243     254487     131630     100126   user:
  457720     109479      44542     303699   swap
  419537     156910      98260     164367   +
  402746     208519     109785      84442   user: @
  402579     209151     103852      89576   @ ;s
  401507     174555      73650     153302   ;s ;s
  381210      98308      17331     265571   var: @
  377418     164606      70945     141867   con:
  354087      95407      33153     225527   ;s col:
  309835     182862      60124      66849   >r
  292806     173229      57072      62505   r>
  275656      28804      16214     230638   0=
  251576     126970      68518      56088   user: @ ;s
  248438     121046      70632      56760   col: user:
  248104     120712      70632      56760   col: user: @
  216244     105626      60494      50124   col: col: user: @
  212251     104129      58946      49176   col: user: @ ;s
  203922     100088      56464      47370   col: col: user: @ ;s
  199820      91949       8004      99867   col: var:
  196434      55035      27799     113600   and
  192467      68884      21938     101645   c@
  187718      83969      57687      46062   !
  182861      99558      41195      42108   over
  170810      36514      22562     111734   col: lit
  169028      44781      19153     105094   col: con:
  167571      31201      41220      95150   cells
  167474      57880      12340      97254   rot
  165683      82438      47254      35991   2dup
  164287      46640      18903      98744   lit col:
  159526      63073       6175      90278   col: var: @
  153550      49352      10997      93201   ;s col: col:
  149816      73999      49793      26024   dup ?branch
  148765      42409      18509      87847   ?branch lit
  142644      66254      48157      28233   ;s @
  141586      55741      43102      42743   branch
  139323          0     139323          0   @local1
  135658      48991        394      86273   col: col: var:
  132375      53809      51672      26894   ;s dup
  131373      46307          0      85066   col: col: var: @
  129236      46217      24350      58669   +!
  127031      61331      37581      28119   col: col: col:
  124565      73765      22169      28631   r@
  121258      19748      19543      81967   =
  118775      18113      18986      81676   = ?branch
  118088      21332       6278      90478   lit col: col:
  116035      52796      35160      28079   ! ;s
  112276      20152       4945      87179   + swap
  111648      39594      17275      54779   +! ;s
  111423      42444      34770      34209   defer:
  109783      76322      17118      16343   con: col:
  108908      55593      29618      23697   ;s @ ;s
  108895      55520      29678      23697   user: @ ;s @
  108895      55520      29678      23697   col: user: @ ;s @
  108895      55520      29678      23697   col: col: user: @ ;s @
  108895      55520      29678      23697   @ ;s @
  108835      55520      29618      23697   user: @ ;s @ ;s
  108835      55520      29618      23697   col: user: @ ;s @ ;s
  108835      55520      29618      23697   @ ;s @ ;s
  108626          0     108626          0   >l
  107819      47709      34723      25387   field:
  106079      55162      25900      25017   col: dup
  106058      43162      42530      20366   ;s dup ?branch
  103985      37694      18983      47308   <>
  103908      47701      31113      25094   field: @
  102930      50665      26789      25476   lit and
  102443      12427       6036      83980   @ dup
  102351      11144       4751      86456   rot + swap
  101933      11014       4755      86164   c@ ;s
  101841      74745      12327      14769   c!
  101661       8350       5782      87529   ;s swap
  101650      36311      18325      47014   <> ?branch
  101169       9853       5732      85584   and 0=
  100983       9776       4751      86456   /mod
   99120      47603      39014      12503   i
   97022      38475      38079      20468   drop
   96461       5054       5071      86336   col: col: con:
   96125      33283      38718      24124   cell+
   93268      44934      18542      29792   count
   92563       2056       7533      82974   ;s col: lit
   92381      22723       8638      61020   0= ?branch
   92040      41023      29797      21220   ;s con:
   89779      35869      33024      20886   -
   88442       7667         43      80732   swap ;s
   88331       7605          0      80726   + swap ;s
   87343      45645      21280      20418   ?branch col:
   87199      34933      18457      33809   ;s lit
   85910          0          0      85910   0= 0=
   85420       4918         13      80489   @ =
   85359       4918         13      80428   @ = ?branch
   84258        249       2912      81097   dup var:
   ... [ that's the top 100 ] ...
   ... [ many, many more lines ] ...
   ... [ and the bottom 50 ] ...
       1          0          0          1   +! ;s ! ;s cells
       1          0          0          1   +! ;s ! ;s (loop) unloop
       1          0          0          1   + @ (loop) unloop var: @
       1          0          0          1   + -rot con: <> ?branch drop
       1          0          0          1   + ! (next) unloop ;s ;s
       1          0          0          1   (next) unloop ;s ;s branch col:
       1          0          0          1   (loop) unloop var: @ ;s ;s
       1          0          0          1   (loop) unloop ;s col: lit col:
       1          0          0          1   (for) var: cell+ i cells +
       1          0          0          1   (for) var:
       1          0          0          1   (for)
       1          0          0          1   (do) lit col: col: col: user:
       1          0          0          1   (do) lit
       1          0          0          1   (?do) var: cell+ i cells +
       1          0          0          1   ! lit (do) lit col: col:
       1          0          0          1   ! lit (do)
       1          0          0          1   ! ?dup ?branch 1- (for) var:
       1          0          0          1   ! ;s cells col: col: user:
       1          0          0          1   ! ;s cells
       1          0          0          1   ! (next) unloop ;s ;s branch
Question: What is (next) ?
Mike B.
PostPosted: Sat Jul 06, 2019 10:43 pm
It looks like Gforth has the FOR NEXT control structure ( not to be confused with the address interpreter NEXT ).
My guess is that (NEXT) is a primitive compiled by NEXT , the control flow word.
