It is currently Tue May 14, 2024 8:40 am
Post new topic Reply to topic  [ 338 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23
PostPosted: Sun Jan 07, 2024 10:16 pm
In my post describing how Fleet Forth handles the text stream I did not show the source for Fleet Forth's WORD . I thought it might be a distraction. Here is the source for Fleet Forth's WORD .
2VARIABLE HISTORY
: WORD  ( C -- HERE )
   'STREAM                  \ Return address and count of remaining text stream.
   BLK 2@ HISTORY 2!        \ Save the contents of BLK and >IN to HISTORY.
   DUP >IN +!               \ Use count from 'STREAM to push >IN past text stream.
   2PICK SKIP               ( delimiter address count )
   ROT 2PICK -ROT SCAN      ( address address2 count2 )
   1- 0 MAX NEGATE >IN +!   \ Use count from SCAN to pull >IN to correct offset.
   OVER - >HERE ;
'STREAM returns the address and length of the remaining text stream.
After the history is saved for use by WHERE and THRU , >IN is set to point just past the text stream.
SKIP returns the address in the text stream of the sought after text and the length of the remaining text stream.
A copy of this address is saved under the address length and delimiter needed by SCAN .
SCAN returns the address of the delimiter after the sought after text and the length of the remaining text stream. One is subtracted from the length. The maximum of this value and zero is subtracted from >IN to put the offset past the delimiter but no further than the end of the text stream.
All that remains are the addresses of the start of the sought text and the address of the delimiter after the sought text. These are converted to the address and count.
Before >HERE is executed, the address of the string and count are on the stack. The address in the text stream, just like Ansi Forth's PARSE-WORD .
>HERE stores this string at HERE as a counted string with a trailing blank. >HERE is a code word for speed.
I could have defined WORD like this:
2VARIABLE HISTORY
: PARSE-WORD  ( C -- ADR CNT )
   OVER - ;
   PARSE-WORD >HERE ;
However, I saw no need for PARSE-WORD . Fleet Forth's find primitives require the address of a counted string rather than the address of a string and a count and CREATE needs a counted string at HERE .
Fleet Forth's 'TEXT returns the address of the string in the text stream and the length. It is like Ansi Forth's PARSE with one difference. If the delimiter is not found in the text stream 'TEXT aborts with an error message.
: 'TEXT  ( C -- ADR CNT )
   DUP>R LIT [ HERE >A 0 , ] C!  \ Store delimiter in ABORT" string.
   'STREAM 2DUP R>               ( ADR LEN ADR LEN C )
   SCAN 0=                       ( ADR LEN ADR2 FLAG )
   [ HERE 3 + A> ! ]             \ If text stream exhausted after SCAN
   ABORT"   MISSING"             \ then the delimiter was not found
   NIP OVER -                    ( ADR CNT )
   DUP 1+ >IN +! ;
'STREAM returns the address and length of the remaining text stream. A copy of the delimiter is stored in the inline string used by ABORT" . After SCAN executes, the address and length 'STREAM placed on the data stack is still there as well as the address of the first occurrence of the delimiter and the length of the text stream after this point. If this length is zero, the delimiter was not found so abort with an error message.
The length returned by 'STREAM is no longer needed so it is NIPped off the data stack and the two addresses are used to calculate the length of the string returned by 'TEXT . A copy of this length plus one is added to >IN .
[Edit: Corrected an error.]
PostPosted: Mon Apr 01, 2024 1:48 pm
An error in one of the machine states in a demo for A Finite State Machine Engine in Forth revealed a shortcoming in Fleet Forth's error handling.
My initial assumption was that words run as background tasks would be fully debugged before set as background tasks. That assumption was in error. When a background task is a word to run through a list of finite state machines, every machine state for every machine installed must be error free. Ideally, a finite state machine should be fully tested before it is installed as one of the machines running in the background, but mistakes do happen.
I've improved Fleet Forth's error handling. Since error reporting uses WHERE to report the location of the error, WHERE was modified to include SINGLE and UNLINK .
: WHERE
   ['] EXIT (IS) RECURSE
   SINGLE UNLINK            \ <- This line was added to switch
                            \ off multitasking and reset
                            \ the user pointer and user area's
                            \ first six user variables.
   HISTORY 2@ TUCK  BLK 2!
SINGLE switches off multitasking and UNLINK points UP (the user pointer) back at the main user area and resets the first six user variables to their boot-up values from the boot area. This causes the main user area's ENTRY to point back to itself, make sure the main task is awake and reset the default stack bases for the return, data, and auxiliary stacks.
With these changes, an ABORT" in one of the machine states for a finite state machine running in the background no longer causes problems in Fleet Forth.
PostPosted: Wed Apr 03, 2024 4:44 pm
One version of the Finite State Machine Engine runs the chain of state machines in the background as a background task. It had the word FSM to initialize the background machine chain and link it into the loop of round robin tasks.
: FSM  ( -- )
   [ ' <FSM> >BODY ] LITERAL
   BACKGROUND-MACHINE-CHAIN ACTIVATE
   BACKGROUND-MACHINE-CHAIN LINK-TASK
   MULTI ;
This word could not be executed more than once or the task for the background machine chain would be linked more than once, breaking the loop. I saw this as a design flaw in Fleet Forth's multitasker so I fixed it.
I added the word LINKED? to test if a task is already linked. Rather than burden the user with testing if a task is linked, I added this word to LINK-TASK , the word which links tasks. If a task is already linked, LINK-TASK does not try to link it again. It is idempotent.
: LINKED?  ( TADR -- FLAG )
   ENTRY
   BEGIN
      @ DUP 2PICK <>
   WHILE
      DUP ENTRY =
   UNTIL
      0=
   THEN
   0<>  NIP ;
: LINK-TASK  ( TADR -- )
   DUP LINKED?
   IF  DROP EXIT  THEN
   ENTRY 2DUP @ SWAP! ! ;
PostPosted: Thu Apr 18, 2024 11:49 pm
JimBoyd wrote:
Here is DOWN-COUNTER for Fleet Forth.
: DOWN-COUNTER
   2VARIABLE  ( -- )
   DOES>  ( -- ADR )
      JIFFY@ DROP
      OVER 2+ @
      OVER -  0 MIN
      2PICK +!
      OVER 2+ ! ;
That '0 MIN' is to handle the case when the jiffy timer resets to zero when it reaches twenty four hours.
A down-counter, a child word of DOWN-COUNTER , has two cells of storage. The first cell holds a value. The second cell holds the low cell of the Commodore 64 jiffy clock from the last time the down-counter was executed. Each time a down-counter is executed the amount of time, in jiffies, which passed from the last time is subtracted from the value in the first cell.
DOWN-COUNTER DELAY1 OK
300 DELAY1 ! OK
DELAY1 ? 209  OK
DELAY1 ? 118  OK
DELAY1 ? 5  OK
DELAY1 ? -445  OK
Of course, the values returned each time I type "DELAY1 ?" depends on how long I wait.
Here is a slightly improved version of DOWN-COUNTER .
: DOWN-COUNTER
   2VARIABLE  ( ++ )
   DOES>  ( -- ADR )
      JIFFY@ DROP           \ Only need low cell of jiffy clock
      OVER 2@ SWAP 2PICK -  \ new.time value -delta.time
      0 MIN                 \ Compensate for reset at midnight.
      +  2PICK 2! ;         \ add negative time difference to
                            \ old value and store new time
                            \ and new value to down-counter
                            \ variable and leave address.
JIFFY@ leaves the value of the Commodore 64 jiffy clock on the stack as a double number. Yes the jiffy clock resets to zero after twenty four hours.
2PICK is syntactically equivalent to 2 PICK .
CODE 2PICK  ( N1 N2 N3 -- N1 N2 N3 N1 )
   4 ,X LDA  5 ,X LDY
   AYPUSH JMP  END-CODE
A DOWN-COUNTER is used when some code is run periodically, but there is a portion which must be run less often.
DOWN-COUNTER DELAY
   DOWN-COUNTER @ 0<          \
   IF                         \ If this code fragment is run often enough
      #3600 DOWN-COUNTER !    \ <DO.SOMETHING> only runs
      <DO.SOMETHING>          \ once a minute.
   THEN                       \
PostPosted: Tue Apr 23, 2024 10:37 pm
Fleet Forth is not a multi user Forth system. It was designed for one person to use at a time on a Commodore 64. Fleet Forth supports multitasking with background tasks. With this in mind the Fleet Forth system has only ten user variables. More user variables can be added.
The user area for the foreground task is not part of the loadable image, it is in a section of unused memory on the Commodore 64; therefore, the first eight user variables need initialized at bootup. Fleet Forth's boot area holds the bootup values for the first seven user variables.
ENTRY  -- Points to next task's user area or itself if no other tasks.
READY  -- Flag. TRUE - task is awake. FALSE - task is asleep.
TOS    -- Holds the return stack pointer when a task is switched out.
RP0    -- Base of return stack.
SP0    -- Base of data stack.
AP0    -- Base of auxiliary stack.
DP     -- Dictionary Pointer.
The first six user variables are initialized by the word UNLINK , which also sets the user pointer UP to the address of the foreground task's user area. This unlinks all background tasks and restores control to the main task. UNLINK is included in a routine included in the coldstart and warmstart routines.
The word EMPTY initializes DP from this bootup area and branches into the body of FORGET to handle any necessary pruning. EMPTY is included in the coldstart routine.
These are the next three user variables:
BASE   -- Base for numeric conversion to or from text.
DPL    -- Decimal place.
HLD    -- Holds the address for the next character during conversion
          from text to a double number.
DECIMAL , which sets BASE to decimal, is included in the routine which is included in the coldstart and warmstart routines.
DPL and HLD are not initialized during coldstart or warmstart. It is not required. NUMBER? initializes DPL and <# initializes HLD .
The Fleet Forth system has only ten user variables. The other variables in the system are not user variables as they should not be needed in background tasks.
As I mentioned, Fleet Forth allows the defining of new user variables. The word for this is USER . It takes a number and is followed by a name.
<USER.AREA.OFFSET> USER <NAME.OF.USER.VARIABLE>
For example:
#20 USER STOOGES
To make defining new user variables easier (some may be defined in different sources), Fleet Forth has a 'system value' or 'soft constant' #USER .
The source for Fleet Forth's USER .
: USER  ( N -- )
   DUP 2+ #USER UMAX (IS) #USER
   CREATE C,
   ;CODE  ( -- N )
      2 # LDY  CLC
      W )Y LDA  UP ADC
      UP 1+ LDY  CS IF  INY  THEN
      AYPUSH JMP  END-CODE
If #USER has the value #20, the following:
#USER USER LARRY
#USER USER CURLY
#USER USER MOE
will create the user variable LARRY with the user area offset #20, the user variable CURLY with the user area offset #22, and the user variable MOE with the user area offset #24.
To set aside more of the user area for a particular user variable, the following can be done.
#USER USER LAUREL
#USER 8 + USER HARDY
This will 'allot' eight more bytes in the user area for the user variable LAUREL .
PostPosted: Sun Apr 28, 2024 9:39 pm
JimBoyd wrote:
I've just streamlined DJIFFIES , the word that takes a positive double number and waits that many jiffies ( 1/60th of a second on the Commodore 64 ) . It is also used by JIFFIES , the word that takes an unsigned single number and waits that many jiffies.
DJIFFIES works by keeping the number of jiffies to delay on the stack as well as the latest jiffy clock value. Each time through the loop, it subtracts the difference from the amount of time to wait. The idea came from DOWN-COUNTER on page 130 ( 140 of the PDF ) in the book Real Time Forth by Tim Hendtlass.
When I was testing my multitasker, I noticed that the loop in DJIFFIES runs several times per jiffy. With three background tasks, two using DJIFFIES ( actually JIFFIES ) for a delay and one counting how many times it runs, the entire round robin runs several times a jiffy. I realized that when the difference between the current jiffy clock value and the previous one is subtracted from the amount of time to delay, either 0 or -1 is added to the remaining time. I only needed to use the lower cell of the jiffy clock value. Here is the code:
SCR# 41
// DJIFFIES
HEX
// TAKES POSITIVE DOUBLE NUMBER
// AND DELAYS THAT MANY JIFFIES
: DJIFFIES  ( D+ -- )
   JIFFY@ DROP
   BEGIN
      PAUSE
      JIFFY@ DROP  DUP>R -
// COMPENSATE FOR RESET AT 24 HOURS
      0 MIN
      S>D D+  R> OVER 0<
   UNTIL
   DROP 2DROP ;
SCR# 42
// JIFFIES
HEX
: JIFFIES  ( U -- )
   0 DJIFFIES ;
JIFFIES takes an unsigned number and has a maximum delay of:
18 minutes 12 seconds and 15 jiffies.
DJIFFIES takes a positive double number and has a maximum delay of:
414 days 6 hours 3 minutes 14 seconds and 7 jiffies or
2,147,483,647 jiffies.
Because DJIFFIES waits until the count goes negative, DJIFFIES and JIFFIES wait one jiffy more than what is requested. Not a big problem. There is an easy solution. Just subtract one from the initial value returned by JIFFY@ DROP .
// DJIFFIES JIFFIES
   JIFFY@ DROP 1-
   BEGIN
      PAUSE
      JIFFY@ DROP  DUP>R -
      // COMPENSATE FOR DAILY RESET
      0 MIN
      S>D D+  R> OVER 0<
   UNTIL
   DROP 2DROP ;
: JIFFIES  ( U -- )
   0 DJIFFIES ;
Now DJIFFIES and JIFFIES will wait the requested number of jiffies.
Note: // (double forward slash) is a Commodore 64 Forth alias for \ (backslash) .
PostPosted: Sun Apr 28, 2024 10:16 pm
In a previous post I showed the source for Fleet Forth's word USER , the word to create new user variables. I also mentioned #USER. The only user variables I've ever defined other than the ones defined in the kernel are the three user variables used for multitasking. They have the offsets 0, 2, and 4.
0 USER ENTRY   2 USER READY
4 USER TOS
Other than these three, I have never defined new user variables; therefore, I simplified the source for USER and removed #USER from Fleet Forth's kernel.
: USER  ( N ++ )
   CREATE
      C,
   ;CODE  ( -- ADR )
      2 # LDY  CLC
      W )Y LDA  UP ADC
      AYPUSH JMP  END-CODE
I also had to change the source for the multitasker's task creation word TASK .
// TASK CREATION AND ACTIVATION
: TASK  ( U AP0 SP0 RP0 -- )
   CREATE
        ( -- TADR )
      HERE RP0 LOCAL !
      HERE SP0 LOCAL !
      HERE AP0 LOCAL !
      [ ' STOP >BODY ] LITERAL
      HERE ACTIVATE
      // OPTIONAL
      #10 HERE BASE LOCAL !
      [ 0 HLD LOCAL 2+ ] LITERAL
      HERE +  HERE DP LOCAL !
      #12 UMAX ALLOT ;
Note that HLD is the last user variable defined in the kernel. It has an offset of eighteen. The line
compiles a literal decimal twenty. Since there are a total of ten user variables, this points the task's DP just past the area used by the last user variable. Setting a task's DP to point twenty bytes into a task's user area is done so data stored at a background task's HERE will not overwrite any of the task's user variables.
PostPosted: Thu May 02, 2024 10:19 pm
JimBoyd wrote:
Here is my find and replace function.
: FR
   BEGIN F R AGAIN ; -2 ALLOT
There was one flaw in the editor word FR . As I mentioned, FR can be used to find all occurrences of a given string in a screen and replace them.
FR HEX^DECIMAL
and used in another screen without specifying the strings to perform the same search and replace.
FR
When the editor word F searches for a string, it first parses the text stream for a search string delimited by the caret character to place in the find buffer. If the text stream is exhausted, the old search string remains in the find buffer. Whatever string is in the find buffer is used for the search. Likewise, the editor word I , which is used by R , parses the text stream for a string to insert and places this string in the insert buffer.
If the search string was not found when FR was used with the search and replacement strings specified, the replacement string was never placed in the insert buffer. When FR was then used without specifying the search and replace strings, the string to be found would be replaced with garbage (whatever was in the insert buffer).
The following improvement to FR places the search string in the find buffer and the replacement string in the insert buffer before the first search attempt.
: FR
   >FBUF  >IBUF
   BEGIN  F R  AGAIN -;
>FBUF and >IBUF are the words which parse the text stream and place a string in the find buffer and insert buffer respectively.
With this modification, I no longer have a problem with FR .
Unlike S , F ( find) and R ( replace) are limited to one screen at a time. If F can't find the string it aborts. I'm changing that to QUIT so it will not clear the data and auxiliary stacks.
I made that change.
