It is currently Sun Nov 24, 2024 5:21 pm
PostPosted: Sun Oct 08, 2006 4:24 pm
. . . sort of.
See http://www.falvotech.com/tmp/screenshot.png for the current screenshot of the K2 emulator running.
I should point out that there is no actual Forth software running in ROM just yet -- I needed some text to print to the screen for testing purposes, and couldn't think of anything more impressive than the boot-up banner itself. :)
Code to print a single line of text is as follows:
.proc DrawMeSomeText
; Set the string pointer into the input pseudo-register #0
    lda #msg
    sta I0
    stz I0+2
; Set string length here
    lda #msgLength
    sta I1
; Set drawing coordinates
    stz leftEdge
    lda #5*80   ; 80 bytes per scanline
    sta topEdge
; Reset the font bitmap pointer, and render!
    jsr DisplayUseSystemFont
    jmp DisplayXorText
.endproc
.rodata
msg:
    .byte "Look ma, this is subscript!!"
msgLength = *-msg
Note that a string's horizontal coordinate is expressed in terms of characters, since this is easiest for the 65816 to handle. The vertical component, however, is expressed in pixels, since the hardware is fully capable of supporting it (as there is no text mode, it can draw text on any scanline in the framebuffer's bitmap).
As you can see from the screenshot, rendering double-height characters is easy too. Instead of calling DisplayXorText, just invoke DisplayXorTextDouble. Everything else is the same.
