It is currently Fri Nov 22, 2024 3:46 am
 Post subject: Kowalski Port Updates
PostPosted: Tue May 07, 2024 4:44 am
Figured I should put status up dates for my efforts to port the code here.
The current status is that I've gotten the code to compile, and I can now load up and edit assembly files.
My next task is to get it to load binaries and run the simulator itself.
Here's a screen shot of the current state running on Linux and Windows.
(My Linux box is forwarding its X11 requests to my Windows machine)
PostPosted: Tue May 07, 2024 5:07 am
looking good - thanks for the update!
PostPosted: Tue May 07, 2024 1:03 pm
For context, see this post and others which follow in the topic "Kowalski Simulator Updates."
Yuri wrote:
I'm thinking that I will try branching and seeing if I can port it to using wxWidgets or something so folks can run it on other OSes than Windows.
PostPosted: Thu Jul 04, 2024 9:44 pm
Just a quick update on this.
I now have an automatic build setup on github that will build both Windows and Linux when code is checked in. Hopefully this will be a good start on a simple CD/CI pipeline to have builds and releases automated.
This will also afford automatic unit testing in the future, and building in a clean build environment.
Added a raw binary format loader, and I'm going to proceed with getting the simulator itself to run with some basic 6502 diagnostic software.
PostPosted: Sun Jul 28, 2024 1:25 pm
Changes from 1.4.0.3 have been merged into the wx_port branch.
PostPosted: Thu Aug 01, 2024 9:23 am
Okay, after some head bashing from a weird NULL de-reference bug in wxWidgets, that I still haven't quite figured out, I was able to get the assembler to run on a dirt simple assembly file.
Still needs work in that department; however it is progress.
Next up will be to try and actually run the simulator.
EDIT:
For reference this is where the NULL error is/was.... The debugger wouldn't even let me step into the line..... >_<
PostPosted: Fri Aug 09, 2024 9:44 pm
Working on the memory display:
This is what I have working in action on Linux
I'd like to be able to support displaying different character sets in the right there. (E.g. Petscii)
Are there any other character sets that might be good to show there?
PostPosted: Sun Aug 18, 2024 1:51 am
ATASCII, maybe. Screen code glyphs, maybe, in case a program is not bothering to convert whatever version of ASCII its host uses to screen codes at run time.
PostPosted: Sun Aug 18, 2024 2:13 am
You might use the Unicode control pictures to display the ASCII control codes rather than blanks:
https://www.compart.com/en/unicode/block/U+2400
PostPosted: Sun Aug 18, 2024 3:16 am
I haven't been following this closely; but do you have code page 437?  It's what the pre-Windows IBM PCs used, and has the special characters we use a lot in engineering like ± µ ° ² Φ Ω etc., and a lot of characters that are good for drawing boxes and diagrams.  All the Epson dot-matrix impact printers (which they still make and sell about a dozen models of) support this set natively, so I loaded it also into my HP-71B hand-held computer to override its own Roman-8 set.
PostPosted: Sun Aug 18, 2024 3:43 am
I'll take a look at that one
For Un*x (and presumably Mac) it should already be UTF-8, though it complains a bit if I try to print character 127 (which is a delete character)
Windows has it's own crazy NOT QUITE UTF-16, but IIRC Microsoft has some character set translation functions.
Don't think that should be an issue.
So far the memory dump is working, and the assembler is able to parse my derp test program:
The jump to edit is much like the old goto dialog, but now you can just type in there.
Recognizes decimal, 6502/C style hex addresses.
Also handles special cases of: "zp", "zeropage", "sp", "stack" and "stackpointer" to jump straight to those locations.
You can also prefix with a + or - to do a relative jump.
PostPosted: Sun Aug 18, 2024 3:55 am
Unicode provides a replacement for DEL/0x7f too:
https://www.compart.com/en/unicode/U+2421
PostPosted: Thu Nov 07, 2024 5:04 am
Been a while, wanted to toss an update out there. Got the I/O window reworked, currently maps CP-437 to UTF.
I'm now working through getting the actual simulator code running again and working happily with the new UI bits and bobs. It says it runs, but so far my test application has not generated any output to the I/O window (yet). Still much to go through there.
The core simulator had several direct Win32 calls for sending update messages to the UI and creating Win32 specific threads.
The messages have been replaced in favor of a much cleaner signal/slot system, and isn't tied to any specific UI now.
The threads have been replaced with std::jthread in conjunction with std::stop_token.
In addition the use of newer C++ lambdas/std::bind have helped simplify a lot of the thread boiler plate.
With a fair chunk of that cleaned up, I'm hoping that part can be moved into a standalone library where a command line version might be created in the future.
PostPosted: Sat Nov 09, 2024 9:11 am
Code is running and writing to the IOWindow now!
The smattering of direct calls to the IOWindow have been removed from the simulator.
The simulator now uses a simulated "bus" which it does all of its read/writes from, in combination with an abstract Device class, it should now be possible to create new devices without needing to modify the core simulator itself.
(E.g. one could make a simulated 6551 or 6522 for example)
