It is currently Sun Nov 24, 2024 7:24 pm
 Post subject: Emulator recommendation
PostPosted: Mon Mar 18, 2019 12:12 pm
I want to run code extracts in an emulator to evaluate code size and execution speed. In addition to being able to execute the code in debug like fashion I also want to know number of clock cycles spent, instruction trace, memory access maps, register state, memory inspector, ...
Is there a tool already available that can do this kind of stuff? Open source is of course a bonus.
PostPosted: Mon Mar 18, 2019 1:04 pm
If you're comfortable with C - and it's fairly unusual C - you might be happy to start by tweaking and instrumenting Ian Piumarta's lib6502:
http://www.piumarta.com/software/lib6502/
(If you're happy with tweaking JavaScript then JSBeeb by Matt Godbolt (and friends) might be a good starting point:
https://bbc.godbolt.org/
PostPosted: Mon Mar 18, 2019 3:23 pm
You can try the Kowalski Simulator.
It has is own assembler and debugging tools. You can view memory and registers, use breakpoints and single step. I have made some corrections to the cycle counting and fixed a few other bugs as well.
My latest release is here:
viewtopic.php?f=8&t=5011&hilit=kowalski#p60014
I have used it to develop several timing critical applications, most recent was the 6502 badge that used a bit banged serial output and the IRQ pin as the serial input. A modified badge was also given to Chuck Peddle which was a date and time clock that also counted the number of days since the 6502 was created, and had several scrolling factoids about the 6502. All was being driven completely with cycle counting for keeping the clock updated. See more about the badge here http://www.sunrise-ev.com/6502.htm
PostPosted: Tue Apr 09, 2019 4:21 pm
Vice is also a nice alternative. When you compile from source with the debug option, you get an extra menu option "debug" which allows you to enable tracing of the main cpu. The trace include a dissasembled trace of the instructions executed, together with the state of all the registers and cycle count on each line.
Vice also have a build in monitor doing thr kind of tasks you described
Users browsing this forum: No registered users and 65 guests
