It is currently Sun Nov 24, 2024 10:40 pm
PostPosted: Sun Jul 01, 2012 7:19 pm
The Kowalski 65(c)02 simulator includes an excellent macro-assembler that can be used to generate code for use outside of the simulator. As written, the simulator supports the NMOS 6502 and the Rockwell version of the 65C02. In order to support the WDC version of the 65C02, as well as the 65C816, I devised a set of macros to synthesize the unsupported instructions. I will be making these macros available on my POC website, but am also publishing them here for convenience. I suggest you copy and past the macro list in its entirely into a file named 816macs.65s and INCLUDE that file in your programs.
Worth noting:
  1. If you use JSL to call a subroutine be sure to use RTL to return from it. JSL pushes a 24 bit return address to the stack, and RTL pulls a 24 bit address. Using RTS to return from a subroutine called with JSL will surely cause a major malfunction.
  2. Be sure to correctly set the MPU's register widths before assembling 16 bit immediate mode instructions (e.g., LDAW 1234). A set of macros for that purpose is included in the below listing.
  3. The pseudo-instruction INT N (where N is $00-$FF inclusive) is included for those who plan to use software interrupts for such purposes as calling operating system APIs. The use of INT N rather than BRK followed by a signature byte representing the API number produces some syntax checking that can be modified to suit your particular application.
  4. The WDC instructions COP, STP and WAI are included for completeness. In practice, there is seldom a need to use these instructions, especially STP. I did not include WDM, as that instruction does nothing in the current iteration of the 65C816. COP could be used in place of the BRK instruction in the INT N pseudo-instruction (above) if desired.
;W65C816S INSTRUCTION MACROS
;   These macros implement 65C02 &  most W65C816S native mode
;   instructions that are not recognized by the Kowalski sim-
;   ulator's assembler (e.g., STP & WAI).
         .if !.ref(brl)        ;if macros haven't been defined...
brl      .macro .ad            ;long relative branch
.ba      =*+3
         .byte $82
         .word .ad-.ba
         .endm
cop      .macro .op            ;co-processor
         .if .op > $ff
             .error "MACRO ERROR: "+%0$+": SIGNATURE OUT OF RANGE"
         .endif
         .byte $02,.op
         .endm
jml      .macro .ad            ;JML $bbahal (long JMP)
         .byte $dc,<.ad, >.ad,.ad >> 16
         .endm
jsl      .macro .ad            ;JSL $bbahal (long JSR)
         .byte $22,<.ad, >.ad,.ad >> 16
         .endm
jsx      .macro .ad            ;JSR (<addr>,X)
         .byte $fc,<.ad, >.ad
         .endm
mvn      .macro .s,.d          ;move next <sbnk>,<dbnk>
         .if .s > $ff
             .error "MACRO ERROR: "+%0$+": SOURCE BANK OUT OF RANGE"
         .endif
         .if .d > $ff
             .error "MACRO ERROR: "+%0$+": DESTINATION BANK OUT OF RANGE"
         .endif
         .byte $54,.d,.s
         .endm
mvp      .macro .s,.d          ;move prev <sbnk>,<dbnk>
         .if .s > $ff
         .endif
         .if .d > $ff
         .endif
         .byte $44,.d,.s
         .endm
pea      .macro .ad            ;pea <addr>
         .byte $f4,<.ad, >.ad
         .endm
pei      .macro .ad            ;pei (<dp>)
         .byte $d4,.ad
         .endm
per      .macro .ad            ;per <addr>
.ba      =*+3
         .byte $62
         .word .ad-.ba
         .endm
phb      .macro                ;push data bank register
         .byte $8b
         .endm
phd      .macro                ;push direct page register
         .byte $0b
         .endm
phk      .macro                ;push program bank register
         .byte $4b
         .endm
plb      .macro                ;pull data bank register
         .byte $ab
         .endm
pld      .macro                ;pull direct page register
         .byte $2b
         .endm
rep      .macro .op            ;clear status register bits
         .if .op > $ff
             .error "MACRO ERROR: "+%0$+": OPERAND OUT OF RANGE"
         .endif
         .byte $c2,.op
         .endm
rtl      .macro                ;return long from subroutine
         .byte $6b
         .endm
sep      .macro .op            ;set status register bits
         .if .op > $ff
         .endif
         .byte $e2,.op
         .endm
stp      .macro                ;halt MPU
         .byte $db
         .endm
tcd      .macro                ;transfer .C to direct page register
         .byte $5b
         .endm
tcs      .macro                ;transfer .C to stack pointer
         .byte $1b
         .endm
tdc      .macro                ;transfer direct page register to .C
         .byte $7b
         .endm
tsc      .macro                ;transfer stack pointer to .C
         .byte $3b
         .endm
txy      .macro                ;transfer .X to .Y
         .byte $9b
         .endm
tyx      .macro                ;transfer .Y to .X
         .byte $bb
         .endm
wai      .macro                ;wait for interrupt
         .byte $cb
         .endm
xba      .macro                ;swap B & A accumulators
         .byte $eb
         .endm
xce      .macro                ;swap carry & emulation bits
         .byte $fb
         .endm
;   synthesized long (24 bit) load/store instructions...
;   Long load/store instructions take the form ***L or ***LX,  the latter
;   for indexed operations.  *** represents the parent instruction.   The
;   assembled instruction generates a 24 bit operand to the parent instr-
;   uction.   The actual macro names are lower case.    The macro comment
;   indicates the official WDC assembly language syntax for the  instruc-
;   tion being synthesized.  The bb in the addressing mode symbology rep-
;   resents the bank number.   The address parameter is processed as a 24
;   bit value regardless of size.   Hence the instruction LDALX $01 would
;   be assembled as AF 01 00 00, which disassembles as LDA $000001,X.
adcl     .macro .ad            ;ADC $bbahal
         .byte $6f,<.ad, >.ad,.ad >> 16
         .endm
adclx    .macro .ad            ;ADC $bbahal,X
         .byte $7f,<.ad, >.ad,.ad >> 16
         .endm
andl     .macro .ad            ;AND $bbahal
         .byte $2f,<.ad, >.ad,.ad >> 16
         .endm
andlx    .macro .ad            ;AND $bbahal,X
         .byte $3f,<.ad, >.ad,.ad >> 16
         .endm
cmpl     .macro .ad            ;CMP $bbahal
         .byte $cf,<.ad, >.ad,.ad >> 16
         .endm
cmplx    .macro .ad            ;CMP $bbahal,X
         .byte $df,<.ad, >.ad,.ad >> 16
         .endm
eorl     .macro .ad            ;EOR $bbahal
         .byte $4f,<.ad, >.ad,.ad >> 16
         .endm
eorlx    .macro .ad            ;EOR $bbahal,X
         .byte $5f,<.ad, >.ad,.ad >> 16
         .endm
ldal     .macro .ad            ;LDA $bbahal
         .byte $af,<.ad, >.ad,.ad >> 16
         .endm
ldalx    .macro .ad            ;LDA $bbahal,X
         .byte $bf,<.ad, >.ad,.ad >> 16
         .endm
oral     .macro .ad            ;ORA $bbahal
         .byte $0f,<.ad, >.ad,.ad >> 16
         .endm
oralx    .macro .ad            ;ORA $bbahal,X
         .byte $1f,<.ad, >.ad,.ad >> 16
         .endm
sbcl     .macro .ad            ;SBC $bbahal
         .byte $ef,<.ad, >.ad,.ad >> 16
         .endm
sbclx    .macro .ad            ;SBC $bbahal,X
         .byte $ff,<.ad, >.ad,.ad >> 16
         .endm
stal     .macro .ad            ;STA $bbahal
         .byte $8f,<.ad, >.ad,.ad >> 16
         .endm
stalx    .macro .ad            ;STA $bbahal,X
         .byte $9f,<.ad, >.ad,.ad >> 16
         .endm
;   synthesized stack-based accumulator instructions...
;   Stack-based accumulator instructions take the form ***S or ***SI, the
;   latter for indexed indirect operations.   *** represents  the  parent
;   instruction.  For example, LDAS 1 is equivalent to LDA 1,S &  LDASI 1
;   is the equivalent of LDA (1,S),Y.  The actual macro names  are  lower
;   case.  The macro comment indicates the official WDC assembly language
;   syntax for the instruction being synthesized.
adcs     .macro .of            ;ADC <offset>,S
         .if .of > $ff
             .error "MACRO ERROR: "+%0$+": OFFSET OUT OF RANGE"
         .endif
         .byte $63,.of
         .endm
adcsi    .macro .of            ;ADC (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $73,.of
         .endm
ands     .macro .of            ;AND <offset>,S
         .if .of > $ff
         .endif
         .byte $23,.of
         .endm
andsi    .macro .of            ;AND (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $33,.of
         .endm
cmps     .macro .of            ;CMP <offset>,S
         .if .of > $ff
         .endif
         .byte $c3,.of
         .endm
cmpsi    .macro .of            ;CMP (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $d3,.of
         .endm
eors     .macro .of            ;EOR <offset>,S
         .if .of > $ff
         .endif
         .byte $43,.of
         .endm
eorsi    .macro .of            ;EOR (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $53,.of
         .endm
ldas     .macro .of            ;LDA <offset>,S
         .if .of > $ff
         .endif
         .byte $a3,.of
         .endm
ldasi    .macro .of            ;LDA (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $b3,.of
         .endm
oras     .macro .of            ;ORA <offset>,S
         .if .of > $ff
         .endif
         .byte $03,.of
         .endm
orasi    .macro .of            ;ORA (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $13,.of
         .endm
sbcs     .macro .of            ;SBC <offset>,S
         .if .of > $ff
         .endif
         .byte $e3,.of
         .endm
sbcsi    .macro .of            ;SBC (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $f3,.of
         .endm
stas     .macro .of            ;STA <offset>,S
         .if .of > $ff
         .endif
         .byte $83,.of
         .endm
stasi    .macro .of            ;STA (<offset>,S),Y
         .if .of > $ff
         .endif
         .byte $93,.of
         .endm
;   16 bit immediate mode instructions...
;   Immediate mode instructions that are able to accept 16 bit  operands
;   take the form ***W, where *** is the parent 8 bit  instruction.  For
;   example, ADCW is the 16 bit form of ADC.  The actual macro names are
;   lower case.   It is the responsibility of the  programmer to  assure
;   that MPU register sizes have been correctly configured before  using
;   ***W instructions.  For example:
;      LONGA                 ;16 bit .A & memory
;      LDAW $1234            ;assembles as LDA #$1234
;      SHORTA                ;8 bit .A & memory
;      LDAW $1234            ;won't work as expected!!!
;   The macro comment indicates the official WDC assembly language  syn-
;   tax for the instruction being synthesized.
adcw     .macro .op            ;ADC #<operand>
         adc #<.op
         .byte >.op
         .endm
andw     .macro .op            ;AND #<operand>
         and #<.op
         .byte >.op
         .endm
bitw     .macro .op            ;BIT #<operand>
         bit #<.op
         .byte >.op
         .endm
cmpw     .macro .op            ;CMP #<operand>
         cmp #<.op
         .byte >.op
         .endm
cpxw     .macro .op            ;CPX #<operand>
         cpx #<.op
         .byte >.op
         .endm
cpyw     .macro .op            ;CPY #<operand>
         cpy #<.op
         .byte >.op
         .endm
eorw     .macro .op            ;EOR #<operand>
         eor #<.op
         .byte >.op
         .endm
ldaw     .macro .op            ;LDA #<operand>
         lda #<.op
         .byte >.op
         .endm
ldxw     .macro .op            ;LDX #<operand>
         ldx #<.op
         .byte >.op
         .endm
ldyw     .macro .op            ;LDY #<operand>
         ldy #<.op
         .byte >.op
         .endm
oraw     .macro .op            ;ORA #<operand>
         ora #<.op
         .byte >.op
         .endm
sbcw     .macro .op            ;SBC #<operand>
         sbc #<.op
         .byte >.op
         .endm
;   register size macros...
;   These macros are a convenient way to change the MPU's register sizes
;   without having to remember the correct bit pattern for the REP & SEP
;   instructions.  The assembler itself has no awareness of whether 8 or
;   16 bit immediate mode operands are to be used.   Therefore, it is up
;   to the programmer to use the appropriate instructions.
longa    .macro                ;16 bit accumulator & memory
         rep $20
         .endm
longr    .macro                ;16 bit all registers
         rep $30
         .endm
longx    .macro                ;16 bit index registers
         rep $10
         .endm
shorta   .macro                ;8 bit accumulator & memory
         sep $20
         .endm
shortr   .macro                ;8 bit all registers
         sep $30
         .endm
shortx   .macro                ;8 bit index registers
         sep $10
         .endm
;   INT pseudoinstruction...
int      .macro .op            ;INT <int_num>
         .if .op > $ff
             .error "MACRO ERROR: "+%0$+": INTERRUPT NUMBER OUT OF RANGE"
         .endif
         .byte $00,.op
         .endm
         .endif
   .end
  • 2012/07/03: There was an error in the JSL macro that was spotted by teamtempest, who must've read the thing from end to end. :shock: I accidentally got the copy-and-paste messed up. Instead of just fixing JSL, I went ahead and replaced the entire listing with the newest version, which does more extensive parameter checking, and also implements the long (24 bit) load/store instructions, such as LDA $123456 or STA $654321,X.
  • 2012/07/06: This macro set is also available on my SBC website.
  • 2012/07/21: The macro set now includes the PER (push effective relative address) instruction. The only 65C816 instruction not synthesized is WDM, which has no function in the current version of the '816.
  • 2012/08/16: Please note that I will no longer be maintaining this forum post. If you want the most up-to-date version please visit my POC website and browse to Downloads. Or you can get a current copy of the macros on Garth Wilson's website, as he has a link to the source file (scroll down to the math (including hardware coprocessors), algorithms, OSs, programming languages, programmers' info section).
Last edited by BigDumbDinosaur on Tue Aug 21, 2012 5:12 am, edited 7 times in total.
PostPosted: Mon Jul 02, 2012 12:39 am
If you are going to use INT N for calling an operating system API it would be a good idea to create a macro that calls the API in a more "conversational" way. For example, suppose you want to make an API call that gets data from an active channel (i.e., open file). The required parameters are the channel number, the 16 bit number of bytes to get and the 16 bit address of a buffer in which to store them. You could write the API call as follows:
          shorta               ;8 bit .A & memory
          longx                ;16 bit .X & .Y
          lda #chan            ;channel number
          ldxw 512             ;bytes to get
          ldyw buffer          ;store them here
          int api_read         ;get data
However, a better way to do it might be to define the following macro:
read     .macro .ch,.n,.buf    ;read N bytes from channel CH into buffer BUF
         .if .n
             .if .ch > 255
                 .error "MACRO ERROR: "+%0$+": CHANNEL NUMBER OUT OF RANGE"
             .endif
             shorta
             longx
             lda #.ch          ;open channel
             ldxw .n           ;bytes to get
             ldyw .buf         ;where to store them
             int api_read      ;call kernel API, where API_READ is the API number
         .else
             .error "MACRO ERROR: "+%0$+": INVALID NUMBER OF BYTES"
         .endif
         .endm
Later on in your program, you'd execute the read operation as follows:
          read chan,n_bytes,buffer
          bcs error            ;error, possible EOF
          ...program continues...
Similar techniques would apply to other kernel APIs or, for that matter, non-API library functions, as the Kowalski assembler's macro parser can support a variable number of macro parameters. It's not quite like writing high level code but not quite as tedious as pure assembly language.
PostPosted: Mon Jul 02, 2012 4:06 am
jsl .macro .bk,.ad ;JSL $bbahal (long JSR)
.endm
I'm curious about this definition. It appears to accept two operands, but only one is used (or needed, IIRC). Is there some reason to define it this way?
PostPosted: Mon Jul 02, 2012 5:35 am
         .endm
Good catch! It was an error from an earlier copy-and-paste session in the text editor. Rather than just fix the error, I replaced the macro source with the latest version, which now includes the 24 bit load/store instructions and better parameter checking. Anyone who might have copied the older version should replace with the above. While the erroneous JSL macro will assemble, an attempt to call the macro with a single address as it should be called (e.g., JSL $04ED13) will cause a missing parameter error.
PostPosted: Tue Jul 03, 2012 7:55 am
I finally figured out how to get BRL (branch long) to work with forward branches. The macro list has been updated. I also removed error checks on some macro parameters because they could malfunction under certain conditions.
PostPosted: Sat Jul 21, 2012 5:34 pm
I have again updated the macro listing, adding the 65C816 PER instruction. Unless someone discovers an error in it, this should be the final change to the macros.
PostPosted: Fri Aug 17, 2012 4:44 am
If you want the most up-to-date version of the Kowalski 65C816 macros please visit my POC website and browse to Downloads. Or you can get a current copy of the macros on Garth Wilson's website, as he has a link to the source file (scroll down to the math (including hardware coprocessors), algorithms, OSs, programming languages, programmers' info section).
