It is currently Sun Nov 24, 2024 5:27 pm
PostPosted: Sat Jul 21, 2012 5:43 am
In the process of writing a macro to automate and "error proof" a computational process that I frequently encounter in dealing with things like block and inode allocation maps on disk drives, I ran across an interesting anomaly in the Kowalski simulator. Rather than try to explain it, here's a test program that uses the macro as part of code that computes the number of bits in a hard drive disk block, given the block size in bytes.
   .opt proc65c02,caseinsensitive
shiftfac .macro .op
;   This macro converts a power-of-2 value into the number of shifts
;   required to perform integer multiplication or division using the
;   ASL, LSR, ROL & ROR instructions.  The macro parameter must be 2
;   or an exact multiple of 2, such as 16 or 32768, & cannot exceed
;   65536 (2^16).  The output of this macro is an LDX # instruction.
;   The following example multiplies the value in NUM & NUM+1 by 16,
;   with the remainder stored at NUM+2:
;            shiftfac 16           ;generates LDX #4
;   loop     asl num               ;each left rotate...
;            rol num+1             ;multiplies the number...
;            rol num+2             ;by 2
;            dex
;            bne loop
.shift   .=1
         .if .op != 2
         .else
.shift   .=.shift+1
           .if .op != 4
           .else
.shift   .=.shift+1
           .if .op != 8
           .else
.shift   .=.shift+1
            .if .op != 16
            .else
.shift   .=.shift+1
             .if .op != 32
             .else
.shift   .=.shift+1
              .if .op != 64
              .else
.shift   .=.shift+1
               .if .op != 128
               .else
.shift   .=.shift+1
                .if .op != 256
                .else
.shift   .=.shift+1
                 .if .op != 512
                 .else
.shift   .=.shift+1
                  .if .op != 1024
                  .else
.shift   .=.shift+1
                   .if .op != 2048
                   .else
.shift   .=.shift+1
                    .if .op != 4096
                    .else
.shift   .=.shift+1
                     .if .op != 8192
                     .else
.shift   .=.shift+1
                      .if .op != 16384
                      .else
.shift   .=.shift+1
                       .if .op != 32768
                       .else
.shift   .=.shift+1
                        .if .op == 65536
                          .error "MACRO ERROR: "+%0$+": INVALID OPERAND"
                        .endif
                       .endif
                      .endif
                     .endif
                    .endif
                   .endif
                  .endif
                 .endif
                .endif
               .endif
              .endif
             .endif
            .endif
           .endif
          .endif
         .endif
         ldx #.shift
         .endm
;   test code — computes number of bits in a disk block...
         *=$2000
num      =$00                  ;number storage
blksiz   =512                  ;size of a disk block
n_bits   =8                    ;bits in a byte
         ldx #<blksiz          ;block size LSB
         ldy #>blksiz          ;block size MSB
         stx num               ;set LSB
         sty num+1             ;set MSB
         stz num+2             ;clear overflow
         shiftfac n_bits       ;get number of shifts
         rol num+2             ;by 2
         dex
         bne loop
         brk
   .end
If you copy the above program into the simulator, it will assemble and run without error, and will produce the correct result, which is $001000 or 4096. However, if you examine the logic tree in the macro body you will see the anomaly. :? :roll: :?:
Comments? Has anyone else run into this?
EDIT: This problem has been corrected in an update to the simulator. The current version is now 1.2.11.
Last edited by BigDumbDinosaur on Sun Jul 22, 2012 11:33 pm, edited 1 time in total.
PostPosted: Sat Jul 21, 2012 8:14 am
Seems Kowalski got the expression evaluation for IFs inverted. This ..
   .ORG   $3000
   .IF   1==1
   LDA   #1
   .ELSE
   LDA   #0
   .ENDIF
   .IF   1!=1
   LDX   #1
   .ELSE
   LDX   #0
   .ENDIF
   .end
..generates..
LDA #0
LDX #1
PostPosted: Sat Jul 21, 2012 5:15 pm
   .ORG   $3000
   .IF   1==1
   LDA   #1
   .ELSE
   LDA   #0
   .ENDIF
   .IF   1!=1
   LDX   #1
   .ELSE
   LDX   #0
   .ENDIF
   .end
..generates..
LDA #0
LDX #1
Exactly! I went around in circles for a while with the equality test before realizing that the tests were backwards. Urk!
However, the less-than and greater-than tests seem to be okay.
PostPosted: Sun Jul 22, 2012 4:12 am
   .ORG   $3000
   .IF   1==1
   LDA   #1
   .ELSE
   LDA   #0
   .ENDIF
   .IF   1!=1
   LDX   #1
   .ELSE
   LDX   #0
   .ENDIF
   .end
..generates..
LDA #0
LDX #1
Version 1.2.9 fixes this problem.
PostPosted: Sun Jul 22, 2012 10:24 pm
The latest version is 1.2.11
PostPosted: Sun Jul 22, 2012 11:31 pm
Yep. The version jump was because Mr. Kowalski fixed a problem that developed after he released V1.2.9, which was double-spacing in the listing output. He also got the .PARAMTYPE macro feature working.
PostPosted: Sun Jul 22, 2012 11:39 pm
This is a great update. I've been using 1.2.6 I had found from my limited google searches years ago.
Even though I've never come across the aforementioned issues, thanks for the posts!
PostPosted: Wed Jul 25, 2012 3:43 pm
Still waiting for the instructions in english for the help file. Still a fantastic program, period....
PostPosted: Wed Jul 25, 2012 4:26 pm
It's now 1.2.12.
PostPosted: Thu Nov 30, 2017 9:39 pm
Hi BDD,
I've been searching through the forum for bugs/feature requests/etc with the Kowalski Simulator and found this. Can you describe the purpose and use of the .PARAMTYPE feature?
I will post a consolidated list of bugs and feature requests once its completed.
PostPosted: Thu Nov 30, 2017 11:54 pm
What .PARAMTYPE does is report if a parameter passed to a macro is a character string or a number. Consider the following macro call:
         printstr "This is a test."
Furthermore, suppose the PRINTSTR macro is as follows:
printstr .macro .string
         .if .paramtype(.string) == 2
             (assemble code to process as a character string)
         .else
             (assemble code to process as an address)
         .endif
         .endm
The above macro invocation would process "This is a test." as a character string. On the other hand, the following invocation:
         printstr straddr
would result in the macro handling the parameter as a numeric value, presumably a string's address.
PostPosted: Fri Dec 01, 2017 12:25 am
Ok, thanks. What is the range of values returned then?
2 = string
0 = ?
1 = ?
3 = ?
I'm having trouble finding the details in the source.
thanks!
PostPosted: Fri Dec 01, 2017 1:53 am
2 = string
0 = ?
1 = ?
3 = ?
thanks!
As far as I know, the .PARAMTYPE evaluation returns 1 for numeric and 2 for string.
PostPosted: Fri Dec 01, 2017 2:16 am
thanks a bunch!!!
PostPosted: Fri Dec 01, 2017 10:07 pm
It would also be useful to have other types like character as well. We discussed this on another thread. The Kowalski macros are fairly crippled, especially compared to something like the CA65 assembler. I haven't looked at the source but how hard would it be to disable macros and let the simulator accept input from a more functional macro program?
