It is currently Sun Nov 24, 2024 8:42 pm
 Post subject: Mass storage interface
PostPosted: Thu May 31, 2012 9:47 pm
So, I have my own emulator that I'm playing with. There are adventures about getting a FIG Forth going on it over in the Forth section.
One of my next steps is to add a "disk drive".
I already have 3 memory addresses for character I/O. One to tell me that a character is ready, another to read the character, and a third that I write to in order to put a character on the screen -- poor mans serial I/O without any actual bits and bauds.
For a "disk drive", what do these tend to look like on other systems?
In the end, for my needs, it really doesn't matter. I'm not performance sensitive, nor am I trying to match any specific piece of hardware in any detail. My assembly code will inevitably call some JSR that shrouds the "real work" anyway.
I could do something as simply as pick an arbitrary sector size (128, 512), have a 2 byte sector number, a 2 byte address pointing to the buffer, and a command byte to write a 1 or 2 to to read or write the sector. That's 8-32MB of data, which is -- ample. Add a byte for a "drive number".
I can do a serial protocol of some kind, copy the buffer through an address that I write to over and over. I won't add a "status" byte to check that the writing is done -- yea, that's how it "should be", but not on this system, not now.
But I was curious what disk interfaces look like on actual systems. Should I bother modeling one of those. Not really motivated to play "head, sector, track" games of yor. Math is hard, let's go shopping.
PostPosted: Thu May 31, 2012 9:56 pm
I generic terms, you could look at Hard drives, CF modules in IDE mode, and flash drives as a sequence of blocks. 512 bytes per block seems to be widely used. So, you create a 512 byte buffer. You write data to the buffer and issue a write block command with the block # as a parameter. Same for reading. Issue a read block command with the block # as a parameter. The 512 bytes get moved into the buffer for processing.
Just one way to look at it.
PostPosted: Thu May 31, 2012 10:05 pm
My own preference is for SCSI, in which logical block addresses (LBA) are used. The device being addressed hides the ugliness of converting an LBA into cylinder-head-sector mumbo-jumbo. Disk sectors are 512 bytes each. In SCSI-1 (the original), you use a 21 bit LBA, and can read or write up to 256 blocks (sectors) at a time. So your math gets reduced to some pretty basic stuff. Multiplying or dividing by 512 is easy, nothing more than 9 rotates. If you want to get fancier, use SCSI-2 with 32 bit LBAs. It all works the same.
