YET another UPDATE
the change are as follow
implementation of memroy read & write a byte at a time to the banks without maping them, they still can be mapped with D020 as before
D02A LOWBYTE address (bank relative)
D02B HIGHBYTE address (bank relative)
D02C BANK TO TRANFER TO/FROM
D02D DATA TO/FROM THE BANK
D02E DIRECTION -> FF=WRITE | FE = READ
WRITING FE at DFFF trigger a cpu reset, FF quite the emulator in my linux console version/does nothing on the arduino
EHBASIC example that copy from the EHBASIC ROM BANK to the First 16K RAM bank
to run EHBASIC from it's ROM BANK in woz monitor type
D020: 04
9000R
press C for coldstart
press enter ehbasic should detect the 36K ram by itself
then type in
5 PRINT "COPYING 16K BYTE PER BYTE"
6 PRINT "PLEASE WAIT..."
10 FOR HB = 0 TO 64 : FOR LB = 0 TO 255
20 POKE 53290,LB: POKE 53291,HB: POKE 53292,4: POKE 53294,254
25 A = PEEK(53293)
30 POKE 53290,LB: POKE 53291,HB: POKE 53292,0: POKE 53294,255
35 POKE 53293,A
40 NEXT LB
45 PRINT (HB+1)*256;" BYTES"
50 NEXT HB
on the Arduino this is slow ass, the EHBASIC is 10706 Bytes long, you can hit ctrl+C after 10752 BYTES and return to the woz monitor, swiitch the first 16K ram bank back and run EHBASIC again like this
CALL 65311
D020: 00
9000R
type w for warm start, our copy program should sitll be in the memory in the 36 firsts K; EHBASIC now run from ram bank 1
