It is currently Tue Oct 01, 2024 9:42 am
PostPosted: Thu Aug 19, 2010 8:33 pm
...that's what i'm wondering now while looking at the ROR behavior.
e.g.: ROR Accumulator:
byte src; // just an unsigned 8-bit number
src = (ACC >> 1); // store the rotation temporary
if(C_FLAG) src |= 0x80; // if C was set, then set the #7 bit of the rotation's result
C_FLAG = ACC & 0x1;
Z_FLAG = !(src);
N_FLAG = !!(src & 0x80);
but it's only that? or i'm missing the...:
ACC = src;
...final line?
in that case, flags are setted/reseted relying on the accumulator's (or whatever the source is) final value? or is it correct to change the flags BEFORE the original data gets overwriten?
sorry about my english, i'm from Argentina :S
http://felliniycia.comule.com/
PostPosted: Sat Aug 21, 2010 6:04 pm
Yes, you need the ACC=src line. With that line, it looks correct. The N and Z flags are always based on the final value (for any instruction that affects them), not the original value. For other addressing modes, you would read and write to the appropriate memory location rather than the accumulator, of course.
PostPosted: Sat Aug 21, 2010 9:31 pm
...so it means that the instruction DO overwrite the original data, even in all the others addressing modes.
thanks a lot mate! :wink:
