It is currently Fri Nov 22, 2024 1:55 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 10, 2020 8:11 pm
Druzyek wrote:
vbt wrote:
Druzyek wrote:
vbt, where did you get the copyright message you have in your files on github?
Most are from the original FBA (final burn alpha), it no more exists and became FBNeo)
I will steal this for my own projects if you have no objections.
ok for me, if you make some changes, tell me :)
Druzyek wrote:
Looks like the Sega Master System had a 4MHz Z80, so it's in the same ballpark! I recently looked into the SH4 variant that comes in a calculator I bought a few weeks ago, which is a descendant of the SH2. Single cycle instructions on 32 bit registers should be really fast!
yes it should be fast, i may check some sh4 asm version of 6502 but it's not so easy to convert, i did that on faze (Z80 sh4 asm little endian) and it's a bad souvenir.
PostPosted: Thu Nov 12, 2020 1:42 pm
However, I'd suggest you take a look at Ian Piumarta's lib6502, as that has always looked good to me. There's a slightly enhanced fork here:
https://github.com/ZornsLemma/lib6502-sf
and the original is here:
https://www.piumarta.com/software/lib6502/
lib6502 is nice but contains some asm part, i won't be able to rewrite them.
Another great 6502 emulator is :
https://github.com/Embedfire/ebf_linux_ ... /K6502.cpp
I didn't test it yet just found the nice lookup tables .
PostPosted: Thu Nov 12, 2020 1:48 pm
Hmm, are you looking at something different from what I'm familiar with? I feel pretty confident in saying lib6502 is written entirely in C.
PostPosted: Thu Nov 12, 2020 5:17 pm
oops i've confused with https://github.com/scarybeasts/beebjit :(
PostPosted: Thu Nov 12, 2020 5:24 pm
Hee hee - no problem! (There's also a fancy library format called lib6502)
PostPosted: Thu Nov 12, 2020 5:28 pm
BTW as the Saturn CPU has a small cache, a code-only approach like lib6502 might be a win compared to a table-driven approach. But you can only check this by benchmarking both.
PostPosted: Thu Nov 12, 2020 11:57 pm
you seem to be sure of the different approach, so i will try it, I have 1 game as benchmark tool :
first m6502 ran at 20 fps, i'll tell you the results :)
PostPosted: Fri Nov 13, 2020 7:38 am
I am holding my breath! (In any case, it will be interesting to hear)
PostPosted: Fri Nov 13, 2020 8:25 am
BTW one of the easiest improvements to make, if it's applicable, is this: instead of having the emulator check for interrupts and/or service peripheral modelling on every instruction, run several instructions between checks. If you presently run one instruction at a time, and increase that to four, for example, that can make a huge reduction in the per-instruction overhead, and make a correspondingly healthy performance increase. (When instructions read or write peripheral registers, of course that will usually need to be handled at once. But most instructions don't.)
PostPosted: Sun Nov 15, 2020 1:54 am
I did something like that, that's such great hint i'm looking for :mrgreen:
The interrupt part was moved before the loop, i won 8-10 fps with that trick :
PostPosted: Mon Nov 23, 2020 1:12 am
trying to do an interface over lib6502 :
#include "../burnint.h"
#include "lib6502.h"
#define M6502_READ   1
#define M6502_WRITE   2
#define M6502_FETCH   4
M6502 *mpu = NULL
INT32 libM6502Init(INT32 cpu, INT32 type)
   mpu = M6502_new(0, 0, 0);
   return 0;
void libM6502SetIRQLine(UINT32 vector, UINT32 status)
   if (status == 0)
      M6502_setVector(mpu, NMI, status);
      M6502_setVector(mpu, IRQ, status);
   if (status == 1)
void libM6502_Reset(void)
   M6502_reset(mpu);
INT32 libM6502MapMemory(UINT8* pMemory, UINT16 nStart, UINT16 nEnd, INT32 nType)
   UINT32 cStart = (nStart>>0);
   for (UINT32 i = cStart; i <= (nEnd>>0); i++) {
      if (nType & M6502_READ)   {
         mpu->memory[i] = pMemory + ((i - cStart) << 0);
      if (nType & M6502_WRITE) {
      if (nType & M6502_FETCH) {
   return 0;
void libM6502SetReadHandler(UINT16 nStart, UINT16 nEnd,UINT8 (*pHandler)(UINT16))
   UINT8 cStart = (nStart >> 8);
   for (UINT32 i = cStart; i <= (nEnd >> 8); i++)
      mpu->callbacks->read[i] = pHandler;
void libM6502SetWriteHandler(UINT16 nStart, UINT16 nEnd,void (*pHandler)(UINT16, UINT8))
      mpu->callbacks->write[i] = pHandler;
int libM6502_Execute(int cycles)
   M6502_run(mpu,cycles);
PostPosted: Tue Nov 24, 2020 1:08 am
well, for now, just black screen, i don't see how it manages cycles (no m6502_icount) and interrupt waits like other cores.
i tried to add a loop without success :
# define begin(cycles) for (int i=0;i<cycles;i++){ fetch(); next(); }
PostPosted: Tue Nov 24, 2020 7:35 am
Hmm, not sure what's happening. Are you able to add some printfs, or use a debugger, to see what's happening?
I don't quite understand what you're doing with the nStart and cStart - could you explain?
