It is currently Thu Nov 21, 2024 9:29 pm
Post new topic Reply to topic  [ 413 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28
PostPosted: Sun Aug 25, 2024 5:26 am
8BIT wrote:
Do your system have RAM at $CFFF? That area is listed as IO Block in your source.
         ldx !#hwstack         ;set top of...
         txs                   ;MPU stack
If there is no RAM there, then its possible some of your code is might be causing a longer loop.
The memory map for the $00Cxxx block is I/O from $00C000 to $00C37F, undecoded from $00C380 to $00C3FF, and RAM from $00C400 to $00CFFF.
For instance, this code might be affecting I, M or X flags.
         lda #%00100100
         pha                   ;do MPU...
         plp                   ;test setup...
PLP might be pulling other bits if the stack points to non-RAM.
After coming out of reset and thus with the MPU in emulation mode, it is implied that SP will be $01xx. Hence the above push-and-pull should work on the first pass.  Shortly afterward, when the MPU has been switched to native mode and SP is set to $CFFF, it will still be pointing to RAM.  So the above will work no matter what.
I did verify with my GAL test rig that the GAL in POC V1.4 is correctly decoding the memory map.
I'm working on the corrections and found another issue. The syntax checker in the editor flags the REP and SEP commands with error 6 if you press enter on either line. This is because the syntax checker assembles just the one line without knowledge of the assembler options - SwapBin included. I need to work out how to fix that, maybe adding another registry option on the assembler options to set SwapBin.
I actually have not used the syntax checker, so I was unaware there was a problem with SwapBin.  I just let the assembler report syntax issues and fix them all at the same time.  :shock:
PostPosted: Mon Sep 02, 2024 11:09 pm
I have update the simulator to fix the PEA #$1234 error, the issue with the Y register not updating correctly, cleared the B bit when in 65816 native mode, and fix issues with "Casesensitive" assembler options and added "SwapBin" support to the Assembler Options tab with Registry storage.
Version 1.4.0.5 is now on my website. https://sbc.rictor.org/kowalski.html
thanks!
PostPosted: Tue Sep 03, 2024 12:46 am
Downloaded.  I will give it a test later on this evening...if I can stay awake.  :shock:
PostPosted: Tue Sep 03, 2024 4:25 pm
Updated the GitHub repo:
https://github.com/Kelmar/kowalski/rele ... on_1.4.0.5
PostPosted: Thu Sep 12, 2024 10:48 am
Hi. I started using Kowalski Simulator, it's a very good tool, but I ran into a problem. I have set the input/output to address 0x7F00, where sending data involves writing it to port 0x7f00 and receiving it by reading it from port 0x7f00. It turns out that the terminal built into Kowalski Simulator doesn't work when I enter data into 0x7f00, but works when I enter it into 0x7f01. This forces me to compile two versions of the program, one to check its operation in KS, and the other for my system. Is there an easy way to bypass this problem?
Not working code:
*=$0300
 LDA #$41
 STA $7f00
 BRK
Working code:
*=$0300
 LDA #$41
 STA $7f01
 BRK
PostPosted: Thu Sep 12, 2024 11:59 am
Hello Gregoria,
The answer is yes and no.
For output, you can set the IO area in the Simulator options to $7EFF. This will allow writing characters to $7F00. There may be some side affects if you are using RAM in page $7Exx.
But, input will not be from $7F00. Input is from IO_AREA+4, so in this case it will be $7F03. You will not be able to do both from the same address.
You can set your IO addresses as variables at the top of your code and then you can just change those to assemble for System or Simulator.
; IO_Page = $7F00
cout = $7F01
cin = $7F04
     lda #'A'
     JSR cout
input jsr cin
        beq input
        rts
PostPosted: Mon Sep 16, 2024 3:56 pm
Thank you for the explanation. I have another problem with Kowalski Simulator. How do I save a binary image file larger than 64kB?
PostPosted: Mon Sep 16, 2024 5:42 pm
Use Ctrl-K to open the save program dialog, select binary image, select Options to set the desired memory range in hex (0x0000 - 0x1FFFF would save 128K) and then save the file.  You can subsequently load the saved binary by using Ctrl-L, selecting binary image, etc.
