Indeed it was exciting when it came out in the mid to late 80's:
available then at 10MHz over 30 op codes that executed in a single clock (100ns @ 10MHz) several new instructions not on the 65c02 movable base page (no longer confined to zero page) relative branch (including subroutine) any branch distance indirect indexed jump to subroutine easier parameter-passing via the stack 16-bit stack pointer additional register (Z).
I got a 4MHz sample, but when I tried to use it as a drop-in replacement for a 65c02 in a workbench computer a few years ago, it didn't work. I never did spend the time to find out if there was a timing requirement my board wasn't meeting, or what. The last time I talked to Commodore about it before they went under, they had discontinued it. I don't know how many they made, but I get the idea that it wasn't very many. As attractive as it was, I think the better way to go now would be to just use a 65c02 at anywhere from 4 to 20MHz, which would more than make up for the fact that it's not a 'CE02. Better yet, go for a 65c816. However, if you do find a source and don't buy up the entire inventory (ha ha), let us know! I have the data sheet here. I don't have any way to scan it to send as E-mail, but could copy it and send via USPS if someone needs it.
Garth
_________________ http://WilsonMinesCo.com/ lots of 6502 resources The "second front page" is http://wilsonminesco.com/links.html . What's an additional VIA among friends, anyhow?
