6502.org http://forum.6502.org/ |
[154] MOS 6502 vs WDC 65C02 http://forum.6502.org/viewtopic.php?f=7&t=409 |
Page 1 of 1 |
Author: | apple2man [ Tue Apr 02, 2002 5:40 pm ] |
Post subject: | [154.1] MOS 6502 vs WDC 65C02 |
My project is almost ready, but I have one small question. The monitor program I'm going to use was written for a MOS 6502. Will it work on the 65C02? It's a simple monitor with nothing special, but will the 65C02 run the MOS code? Most of the uP comparisions I've found, discuss the new features, but don't discuss software compatibility. |
Author: | 8BIT [ Tue Apr 02, 2002 11:19 pm ] |
Post subject: | [154.2] MOS 6502 vs WDC 65C02 |
Hi! Your 65C02 should run fine. It supports all the original 6502 opcodes and also has some added opcodes that can make coding a little easier. I know there are many "undocumented" opcodes in the original 6502 that perform useful functions but your monitor code most likely only used the published opcodes. Good luck! Daryl |
Page 1 of 1 | All times are UTC |
Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
