[116] 6502 - 8251 http://forum.6502.org/viewtopic.php?f=7&t=371 |
Page 1 of 1 |
Author: | 8BIT [ Fri Jun 01, 2001 12:24 pm ] |
Post subject: | [116.1] 6502 - 8251 |
I copied this from the PCB discussion to the General Discussion as more people may be able to use it. The new title will make it easier to find. >From AIRUL >I trying to integrate 8251 into 6502 based system, but not working.I >hope you can give me an idea or schematic view and simple test >program to test 8251 in system based on 6502. AIRUL, I have not worked with the 8251 but am willing to help. Do you have a web site address containing the technical specs on the 8251? Do you have a schematic of your system? If so, can you put it on a web site so we can all look at it and help with a solution? Also, any software that you have tried would help too. In the mean time, I'll try to dig up the specs on my own and see what I can do. Daryl (65c02@altavista.com) |
Author: | 8BIT [ Tue Jun 05, 2001 12:19 am ] |
Post subject: | [116.2] 6502 - 8251 |
So far, all I've found that might help is an article about the 8251 used with the Z-80 CPU. It mentions an initialization bug. If anyone else can offer up any help, please do. I was able to get the pinout and register description from the "chip directory" but could not find any other technical data. Here's the article: In article copeland@metronet.com (Charles Copeland) writes: I used a 8251 about ten years ago. There is/was a bug about initializing the chip. The data book I had at the time didn't mention it. Yes, they've eliminated the references to this problem, which is why I've kept my '82 _Component Data Catalog_ all these years. I vaguely remember something about writing 0 out twice to some port to get to kick in. Here what has always worked for me, in Z80 assembler: CON_REG EQU ???? ; CONTROL REGISTER I/O PORT ADDRESS RST_CMD EQU 40H ; 8251 RESET COMMAND MODE EQU 5EH ; 8251 MODE CONSTANT (CLK X 16, 8 DATA BITS, ; ODD PARITY ENABLED, 1 STOP BIT) RST_ERR EQU 15H ; 8251 RESET ERROR FLAG COMMAND INIT_UART: XOR A ; LOAD NULL OUT (CON_REG),A ; SEND NULL TO 8251 NOP ; DELAY OUT (CON_REG),A ; SEND ANOTHER NULL NOP ; DELAY OUT (CON_REG),A ; SEND ANOTHER NULL NOP ; 8251 NOW IN COMMAND MODE LD A,RST_CMD ; LOAD RESET COMMAND OUT (CON_REG),A ; RESET 8251 NOP ; DELAY LD A,MODE ; LOAD 8251 MODE CONSTANT OUT (CON_REG),A ; SET 8251 MODES NOP ; DELAY LD A,RST_ERR ; LOAD RESET ERROR FLAGS COMMAND OUT (CON_REG),A ; RESET AND ENABLE 8251 -- ===================================================================== Michael Kesti | "And like, one and one don't make Grass Valley Group | two, one and one make one." mrk@gvgdsd.GVG.TEK.COM | - The Who, Bargain Hope this helps! Daryl (65c02@altavista.com) |
Page 1 of 1 | All times are UTC |
