It is currently Fri Nov 22, 2024 12:22 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: [84.1] Schematic Labels
PostPosted: Sun Dec 10, 2000 10:07 pm
Hey, on some schematics, there are pins listed like "A0-A15". Are htey labled as A0 or whateve ron the chip? Also, multiple chips hav ethis on my schematci....are they ALL Interconnected to the 6502? THanks!
Report this post
 Post subject: [84.2] Schematic Labels
PostPosted: Mon Dec 11, 2000 5:07 am
The labels you mention refer to the individual lines of a bus, specifically the address bus in this case. By definition, these go to several things in parallel. The A0-A15 coming off the processor though may not go directly to the other A... lines in a larger system. For example, in the Apple II, when memories were small and it took a ton of them to get 32K or 64K of RAM and ROM, a bus driver was used between the processor and everything else, as the processor alone could not drive such a heavy load.
In smaller systems that are more likely to be home-made, the bus drivers are normally unnecessary, so all the A0's would be connected together, for example.
If you're new to microprocessors, the 6502 family offers an easy place to start learning, and an excellent power-to-complexity ratio. You're bound to get hooked.
Garth Wilson
Report this post
 Post subject: [84.3] Schematic Labels
PostPosted: Mon Dec 11, 2000 6:00 pm
Thanks much! Im building Chris Wards' design. You cna find a link on the 6502.or gpage, under the HOMEBUILT PROJECTS section.
Report this post
