It is currently Fri Nov 22, 2024 12:49 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Mon Feb 19, 2001 10:16 am
I've developed a very small bootstrap monitor for the 6502which listens for an Intel Hex download from the serialport (6551) and fills memory as it downloads programsor data at 19200,n,8,1. At this speed, most program downloads go pretty fast.I stuffed a copy of this at:http://www.shortwaveplanet.com/intelhex.asm in caseanyone is interested.If it hears Intel hex, and gets to the "end" record withno bad checksum records, it will jump to $0200 (or whateveryou define instead) and run the just-downloaded program.There are currently no timeouts, and I deliberately run with interrupts and handshaking off, to keepthings maximally simple and as hardware-independentas possible. Some error cases take you back to try again,while others hang waiting for the "second" character of a hex value that never arrives.It's primitive, but seems like just the think for anexperimenter PCB, so you don't have to burn EPROMs forprogram development.-- Ross
The economy isn't "Grapes of Wrath", but it is getting
to be "Raisins of Regret."
-- Ross
Report this post
PostPosted: Fri Feb 23, 2001 3:05 am
Good idea. This is the sort of thing you should give to Mike Nabarezny to put in the 6502.org source code repository. Actually, since it's already on the web, just a note inviting him to copy it over would be adequate.
Report this post
Users browsing this forum: No registered users and 35 guests
