6502.org
http://forum.6502.org/
[47] 6502 Processor Stack pointer
http://forum.6502.org/viewtopic.php?f=7&t=304
Page 1 of 1
Author:  tonyhall1 [ Sun Apr 23, 2000 4:08 pm ]
Post subject:  [47.1] 6502 Processor Stack pointer
Hi Guys,
i have a question about the 6502 processor's stack pointer.
1. how big is the stack area of memory and what does it store and in what format?
2. what does the stack pointer store, a memory location(to what) or a position number within the stack area of memory(e.g. location 2)
Tony
Author:  simonj5 [ Tue Apr 25, 2000 5:07 am ]
Post subject:  [47.2] 6502 Processor Stack pointer
Tony,
The stack pointer in a 65(C)02 is implemented as an 8-bit register that provides an index into the area of memory between 0x100 and 0x1ff. This is part of the main memory map (unlike some microcontrollers that have a seperate memory map for their stacks?). It is byte aligned and contains a mixture of both 'system' and 'user' information. The system information is typically return addresses held, if memory serves, as low-byte then high-byte. Obviously user information can be in any format.
I hope this helps.
Regards,
Simon J
Post subject:  [47.3] 6502 Processor Stack pointer
Tony,
I hope this helps.
Regards,
Simon J
Author:  JIM1831 [ Fri Apr 28, 2000 10:44 am ]
Post subject:  [47.4] 6502 Processor Stack pointer
If I remember correctly, when a JSR instruction is executed, the current program counter is pushed on the stack + or - 2 (something strange like that). Why isn't the return adddress (JSR + 3) put onto the stack for eventual RTS?
I've always wanted to know this.
Jim Lewandowski
Author:  leeeeee [ Fri Apr 28, 2000 4:25 pm ]
Post subject:  [47.5] 6502 Processor Stack pointer
Hi Jim,
You said ...
The return address-1 is pushed (or JSR +2 whichever you prefer to call it). Why? Well after the return address is pulled from the stack the program counter is incremented by one before the next instruction is fetched.
You know it all makes sense.
Lee.
Page 1 of 1 All times are UTC
Powered by phpBB® Forum Software © phpBB Group
http://www.phpbb.com/
