It is currently Fri Nov 22, 2024 1:12 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Tue Jul 11, 2000 12:05 pm
Hello all
I'm trying to repair an old Gould strip chart recorder which uses
an R6502-11 processor. I need to replace the processor but can't seem to find one. Is the W65C02S a plug in replacement? Most of the other chips on the board are LS TTL. If so where can I get one?
I'm also looking for an MC6810P for the same board. any ideas?
Thanks in advance,
Robleak
Report this post
PostPosted: Tue Jul 11, 2000 9:56 pm
I would guess that the 65C02 is "most likely" to be OK in the board.
I plugged one into a VIC-20 board, and it worked fine.
Last time I looked, Jameco stocked 65C02 chips.
Pete
Report this post
