It is currently Wed May 22, 2024 3:49 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Fri Mar 31, 2000 3:12 pm
Just wondered if anyone else is interested in emulating the 6502. Personally, I've been involved in one small emulation project in the past, related to college written in GNU c++...Later.
Report this post
PostPosted: Sat Apr 08, 2000 11:22 pm
There is an emulator for the 6502 out there at www.emulator.org (I think) Hope this helps.
A.S.
Report this post
PostPosted: Wed Apr 26, 2000 3:46 pm
There are a number of 6502 emulators, hidden in C64 emulators, VIC20 emulators, Apple II emulators etc.
Just grab one.
(The VICE emulator is even GPLd, so follow the links from http://www.6502.org/users/andre)
Andre
Report this post
PostPosted: Fri Apr 28, 2000 2:25 am
Site Admin
Andre,
You are more familiar with the 6502 emulators than anyone here. Could you be convinced to throw together a simple emulator for the PCB Project? It would need to emulate the 6502, 6522, 16550, and do I/O through a simulated RS-232 dumb terminal.
Report this post
PostPosted: Fri Apr 28, 2000 12:32 pm
Hi Mike,
I was afraid you´d say something like this ;-)
[Building a PCB Project emulator]
The problem is I don´t actually have the time to do this, but I´ll see what I can do (maybe I use this as finger-practice for my new cvs knowledge I got :-)
Can´t give a time schedule, though.
Ah, and it´ll only run on Linux, although porting the thing to DOS/Win should after that only be a matter of rewriting some menu files in arch/dos or arch/win in the VICE source (I guess I could use the 6545 emulation for the terminal, so I don´t need to make some custom code ;-)
Andre
Report this post
