Hi, Welcome to the group.
For an original NMOS 6502, the phase-0 input frequency is 1 Mhz (or less - I don't remember what the minimum speed is).
However, there are many 6502A's, which are rated for 2 Mhz. This chip was used in lots of early machines, such as the Commodore VIC-20. Look closely on the chip for the "A" - it was often stamped on the device separate from the normal markings, because they were "select in test" devices: in manufacturing, they tested the part at different speeds, and if it worked at 2 Mhz, it got the "A" stamp. Otherwise, they sold it as a 1 Mhz part.
I also have a 6502B, which is supposed to run at 3 Mhz.
Also, there is a 6502C that was used in the Atari 800 computer, but it is *not* a 4 Mhz part; rather it is 2 Mhz. The "C" is because it has some minor difference in the bus signals. As far as I know, only Atari used this version.
The original brands are MOS Technology (*not* the same as Mostek), Rockwell, and Synertek. The earliest dates are 1976 I think. [ This reminds me: if anyone in the group has an early chip that they would trade for something else, let me know. First choice would be a 6502 that does not implement the ROR instruction. It would probably have an early 76 date code. ]
In "modern times", there are now CMOS 65C02 parts, which are available at up to 14 Mhz. I think they are all marked such as "W65C02-10", which is a 10 Mhz part. Western Design Center is the primary vendor of the C02, but there are 2 or 3 other brands also, I think.
Pete
