It is currently Sat Nov 23, 2024 10:11 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Mon Aug 12, 2002 8:47 pm
I have some equipment with the R6511AQ microprocessor onboard. The processor is in a 64-pin QUIP. I have no manuals for this device. It is descended from the 6502 and seems to have many of the same instructions in eprom - at least I can decompile the software into a form that seems to make sense relative to a 6502, but there are opcodes that seem to make no sense at all.
I'd like to convert my equipment to something more recent, such as a '286 or even a Z80. To do this, I first have to find out exactly what my equipment is doing. I do not have access to, nor the time for using, a logic analyzer.
Do you know of any locations that have the data manuals for this specific processor? Because it is in a 64-pin QUIP, and not a 40-pin DIP, it does not match any of the other 65xx data manuals that I have.
Thank you
Mark Barner
barnermark
@hotmail
.com
Report this post
PostPosted: Tue Aug 13, 2002 1:08 am
I have the '87 databook with the R6511Q in the 64-pin QUIP. Is it the same thing? I could copy the 35 pages for you and send by USPS if you give me an address. I'm sure Rockwell would no longer care if I copy it. This microcontroller does not have the extra CMOS instructions except that it does have BBR, BBS, RMB, and SMB whose op codes end in 7 and F. Otherwise there may be data mixed into the code as parameters to pass to subroutines, for example, to display literal data.
Garth
Report this post
PostPosted: Sun Aug 18, 2002 7:39 pm
Hello Mark,
It is always interesting to hear about 65xx devices being used in
commercial products. If you have the time, could you tell us alittle
about the product containing the 6511 ?
Best Wishes, Wally
Report this post
PostPosted: Sun Aug 18, 2002 11:04 pm
Mr. Daniels,
As the application is proprietary, I can not give you any specific details, except to say that the current design exploits every feature and port available on the R6511Q.
Mark Barner
Report this post
PostPosted: Sun Aug 18, 2002 11:09 pm
Mr. Wilson,
Thank you for faxing the copy of the R6511Q manual. I am currently writing my own decompiler using the information from the manual. It looks like I will be able to use a vintage form of TASM (c. 1987) to re-compile and test my assumptions about this processor. I'll let you know what I can, as long as it does not violate any proprietary agreements with my current employer.
Mark Barner
Report this post
PostPosted: Mon Aug 26, 2002 10:20 pm
Site Admin
Hi Garth,
I've had a surprising number of requests for the R6511AQ datasheets. Would you consider photocopying and mailing it to me? I'll reimburse your costs. I would like to scan it and put it and the Datasheets Archive on 6502.org
Best Regards,
Mike
Report this post
PostPosted: Tue Aug 27, 2002 11:27 am
Hi,
I used in past 6501Q.
In what I know 6511AQ is a faster version of 6501Q.
Both are no longer produced by Rockwell.
I can send digital copy (scanner photocopy) of the original Rockwell datasheet. Design replacements of 6501 could be some of the Mitsubishi microcontrollers of the 740 series.
Regards
Mauro
Report this post
PostPosted: Thu Aug 29, 2002 3:55 pm
>I'd like to convert my equipment to something more recent.....
Hello Mark,
Any chance that you might have or end up with some spare R6511Q
chips??? I am looking for some to complete a project. Please let
me know.
Regards,
Robert
rdoerr@bizserve.com
Report this post
