I have memorized the following:
1. Old schematics using PHI2O can be used with no alteration if one is using old stuff (NMOS and CMOS).
2. If one is going to use a
WDC65C02 things
might work (low clock speed, slow RAM, ROM, I/O) without any issues.
3. Using PHI2O on a (new) WDC 65C02 is
not recommended (that is explicitly said in the data sheet). Together with fast RAM (< 70ns) there is a good chance to run into spurious errors. Use PHI2(in) = the output of your can oscillator instead.
Of course: all this assumes that the used schematics itself are free of errors.
When using a
WDC65C02 it is
better to use PHI2(in) (signal at DIL pin 37) instead of PHI2O (DIL pin 39) even when slow peripherals are used.
When using a
WDC65C02 careful check the usage of the RDY signal. This is now an
I/O signal (on all other 6502 it is input only).
If you wish to go beyond 10 MHz reading and understanding
Generating Wait-States with Clock Trickery is recommended.
Regards
