It is currently Thu Nov 21, 2024 12:52 pm
PostPosted: Sat Apr 27, 2024 2:25 pm
I've added several commands that send values from EhBasic to my graphics routines, and can thus draw lines and change colors, etc.
However, I'm having trouble figuring out how to send values back the other way. I just get a syntax error.
Can someone give some example code to do such a thing? I'd like to do the same with two or three parameters as well.
I have two commands, VEEK and VOKE. Much like PEEK and POKE, but it does the same with my TMS9918a VRAM. VOKE works just fine.
I'd like to do something like:
10 A = VEEK(2035)
or
20 IF PIXEL(230,61) = 1 THEN A$="You hit a wall"
What am I missing?
Here's EhBasic's code:
BAS_PEEK
      JSR   BAS_F2FX          ; save integer part of FAC1 in temporary integer
      LDX   #$00              ; clear index
      LDA   (Itempl,X)        ; get byte via temporary integer (addr)
      TAY                     ; copy byte to Y
      JMP   BAS_1FD0          ; convert Y to byte in FAC1 AND return
Here's my code: I don't touch X at all.
basVEEK: ; get a byte from an address in the TMS VRAM
    LDA Itempl        ; get byte via temporary integer (addr)
    STA TMS_TMP_ADDRESS
    LDA Itemph
    STA TMS_TMP_ADDRESS +1
    JSR tmsVRAMAddrSetRead
    NOP
    NOP
    NOP
    NOP
    NOP
    LDY TMS_VRAM
    CLI
Robb
PostPosted: Sat Apr 27, 2024 3:07 pm
I've figured it out. After typing the above, I had a revelation.
Rather than slipping in the function into the end right above TK_IRQ, you slip it after TK_DEEK along with other functions so that it can be pre-processed.
Just replicate the arrangement under BAS_FTBM.
      .word BAS_PEEK-1        ; PEEK()
      .word BAS_DEEK-1        ; DEEK()          new function
      .word basVEEK-1           ; VEEK()
      .word BAS_SADD-1        ; SADD()          new function
      .word BAS_LENS-1        ; LEN()
      .byte 5,'P'             ;
      .word LBB_PEEK          ; PEEK
      .byte 5,'D'             ;
      .word LBB_DEEK          ; DEEK
      .byte 5,'V'
      .word LBB_VEEK          ; VEEK
      .byte 5,'S'             ;
      .word LBB_SADD          ; SADD
      .byte 4,'L'             ;
      .word LBB_LEN           ; LEN
      .byte 5,'S'             ;
TK_PEEK           = TK_ATN+1        ; PEEK token
TK_DEEK           = TK_PEEK+1       ; DEEK token
TK_VEEK           = TK_DEEK+1       ; VEEK token
TK_SADD           = TK_VEEK+1       ; SADD token
TK_LEN            = TK_SADD+1       ; LEN token
TK_STRS           = TK_LEN+1        ; STR$ token
      .word BAS_PPFN-1        ; PEEK(n)         "
      .word BAS_PPFN-1        ; DEEK(n)         "
      .word BAS_PPFN-1        ; VEEK(n)         "
      .word $0000             ; SADD()    none
      .word BAS_PPFS-1        ; LEN($)    process string expression in ()
LBB_VAL
      .byte "AL(",TK_VAL      ; VAL(
LBB_VEEK
      .byte "EEK(",TK_VEEK    ; VEEK(
LBB_VMODE
      .byte "MODE",TK_VMODE   ; VMODE
I hope this helps someone else.
Robb
PostPosted: Sat Apr 27, 2024 10:07 pm
robbbates wrote:
BAS_PEEK
By surrounding your code with CODE tags, it becomes easier to read.
PostPosted: Sat May 04, 2024 1:00 pm
Welcome, Robb! Glad you figured it out, and thanks for sharing your technique.
