It is currently Thu Nov 21, 2024 4:38 pm
 Post subject: How to build.....
PostPosted: Sat Nov 29, 2008 6:34 am
Hi,
What assembler should I use to build EhBasic if not using the simulator ?
Cheers.
Phill.
PostPosted: Thu Dec 04, 2008 1:12 am
You can assemble in the simulator and save an image of the memory, that's what I do.
PostPosted: Thu Dec 04, 2008 10:42 am
Yeah I eventually worked out how to do that :)
However as a more perminent solution I converted the code (via a conversion program, written in delphi), to assemble with BeebAsm, as this is what I was using for other projects, that seems to work fine now.
Cheers.
Phill.
PostPosted: Thu Dec 04, 2008 7:44 pm
I actually have used the freeware TASM 3.01 (Table Assembler) from Squak Valley Software. I don't remember if I had to do some preprocessor conversions (like the format of preprocessor directives... "db" versus ".db" for instance) but as I recall, it didn't take long to do.
Rich Cini
Build Master and maintainer of the Altair32 Emulation project
http://cini.classiccmp.org
http://altair32.classiccmp.org
