It is currently Sat Nov 23, 2024 12:17 pm
 Post subject: random number generation
PostPosted: Fri Jan 03, 2003 5:07 am
hi,
I was just wondering how random numbers are generated ? I am using EnhBASIC to display patterns on a text screen but the patterns don't seem very random. I'm wondering if this is a problem with hardware or is it a built in feature of EnhBASIC ?
PostPosted: Fri Jan 03, 2003 11:59 pm
Hi Rob,
The RND() function in EhBASIC uses a 31 bit maximal length PRNG.
I chose this for two reasons - speed, and it ensures all the values
will eventually be produced.
If you want a more random seeming sequence then use every nth
value (where n is a suitable large prime number). EhBASIC68k
uses every 5th value to this end.
Lee.
cron
