It is currently Thu Nov 21, 2024 10:23 pm
PostPosted: Fri Jun 14, 2024 7:38 am
I just got an end-of-life notification from mouser for this https://www.mouser.de/ProductDetail/955-W65C22N6TPLG-14
It's the N-version of the 6522, in PLCC package. N-version means that it's electrically compatible with the NMOS 6522.
I understand that anything PLCC is not NMOS by origin - except maybe for my Micro-PET clone where I use PLCC to save board space - so, it's a reasonable decision to set it to end-of-life.
In my Micro-PET I think I can use the S version also.
The DIP-40 N-variant is still available and not end-of-life (yet...): https://www.mouser.de/ProductDetail/Wes ... 22N6TPG-14
André
PostPosted: Fri Jun 14, 2024 5:57 pm
Same notification is on the English version of the product page.
On the other hand, the S-version has plenty of stock and no EOL notification.  I'm guessing WDC’s inventory of the most recent run of N-version production is almost depleted, and no more production is planned.
Other than the totem-pole IRQ output, I don’t see any technical issues with using the S-version...and adapting for the totem-pole IRQ is trivial.
One thing in the S-version’s favor is it has the T6 core, which is the same as used with the current versions of the 65C02 and 65C816 (the 6 refers to the 0.6µ geometry).  At least in the 65C02, plasmo has demonstrated that the T6 process can be run in the 30 MHz range.  I wouldn’t be particularly surprised if the 65C22S could run at least in the 20+ MHz range.
PostPosted: Mon Jun 17, 2024 10:56 am
One question that came to my mind - maybe not relevant for most schematics, maybe not even making sense, I didn't look up the details in the datasheet (which I remember are not very good in that aspect):
Could it result in problems when interfacing a 5V W65C22S with a 3.3V CMOS device? I know that driving 5V TTL inputs on devices like 74HCT with a 3.3V CMOS output works, as the min Voh of the CMOS is still over the max Vih of the TTL input. In one of my boards, I drive the address and select lines on a 5V W65C22N from a 3.3V CMOS FPGA, basically relying on what has been long experience (but not fully documented IIRC) about the 6522 inputs (data bus is going through a level converter, as it's bi-directional)
Would that potentially give problems when replacing the N with the S-type 6522?
André
PostPosted: Mon Jun 17, 2024 11:59 am
I can vouch that driving from a 3.3v CPLD to a 5v W65C22 works fine. It’s how I’m doing it in my own board, running at days at a time with no issue at 25MHz.
PostPosted: Mon Jun 17, 2024 12:23 pm
Are you using the S or N variant?
PostPosted: Mon Jun 17, 2024 11:47 pm
Sorry, I forgot to specify. I'm using the 'S' variant.
PostPosted: Wed Jun 26, 2024 9:29 pm
According to the data sheet, the W65C22N has TTL input thresholds (high >=2V, low <=0.8V) whereas the W65C22S has CMOS thresholds (high >= 0.8VDD, low <= 0.2VDD). That seems like a big difference to me. OK, in reality the threshold for the W65C22S is probably near 0.5VDD, but still significantly different from the W65C22N.
PostPosted: Thu Jun 27, 2024 1:27 am
Bill Mensch has said that the input threshold for the WDC microprocessors is at ~50 percent of VCC, which was verified by some testing that Jeff did.  I’d expect the 65C22S would have a similar threshold.  Helping matters is the fact that devices with TTL-compatible outputs can theoretically reach VOH = 3.4 if lightly loaded.  That, of course, easily exceeds the 50 percent level.
In a 65C816 system, more robust operation will be achieved with the use of a data bus transceiver with TTL-compatible inputs, e.g., a 74AHCT245, as depicted in the 65C816 data sheet.  The transceiver will also help to eliminate the risk of bus contention on the rise of the Ø2 clock during a read cycle.  The same transceiver could be used with the 65C02 if there is concern about a device’s output being on the weak side.
PostPosted: Thu Jun 27, 2024 4:04 am
My main concern would be the use of a W65C22 with 5V supply, but the address, select, and control lines being driven by a 3.3V CMOS output.
PostPosted: Thu Jun 27, 2024 6:23 pm
Based on what Bill Mensch has said about input thresholds, that would appear to be workable—if you can live with a reduced noise margin and the possibility that parasitic capacitance might give you some timing headaches.
