I'm using W65C22
N (yes, NMOS-compatible version), I bought it from Mouser, so it must be a modern part.
(My 6551 is also W65C51
N - I preferred them over CMOS versions because of open-drain /IRQ that can be wire OR'ed, and also because I want them to be compatible with some of my other NMOS chips that I might be adding to my SBC).
I'm reading PS/2 in a bit-banging fashion through 65C22N:
- PS/2 data -> PB4
- PS/2 clock -> CB2
I have my VIA fire an interrupt on the falling edge of CB2:
lda #%01111111 ; Disable all interrupts
sta VIA1_IER
lda #%10001000 ; Set interrupt flag for CB2 (page 27)
sta VIA1_IER
My ISR then counts 11 bits and registers a "key pressed/released" flag.
However I'm sometimes getting weird /IRQ assertions when pressing keys on a keyboard (happens <1% of time, but is annoying as hell):
The green circle shows a place where /IRQ is asserted despite CB2 is rising. You can clearly see that it's aligned with CB2. This results in clock skew, so now all my PS/2 packets are off by 1 bit. This happens in random places.
- My /IRQ is pulled up with 5K resistor. Same issue is reproducible with my another SBC which has a 3.3K pull-up.
- Both PS/2 lines are pulled up with 1K resistors.
- No other hardware is using /IRQ - it's wired only from 65C22N to 65C02S (I've removed 65C51N for debugging.)
- My ISR takes ~4us to clear VIA's interrupt flag (I'm doing that as early as possible) and you can clearly see that the /IRQ line is released normally.
- This seems to occur much more frequently when I rapidly slam my keyboard. However, my logic analyzer still properly decodes PS/2 packets.
- I'm running @ 8 MHz.
Why could this be happening?
EDIT: This is also reproducible with another keyboard AND with another revision of my SBC (which has totally different PCB traces, so I highly doubt that crosstalk is involved.)
<s>EDIT 2: I'm going to try another VIA for this. That's the only part I've reused in both builds. I highly doubt that it's my software that's guilty - the code is very simple.</s> nope - same issue with a different W65C22N.
EDIT 3: Could it be due to mixing W65C02S & W65C22N?
EDIT 4: I think I should replace my 'N chips with 'C versions and join IRQ lines through 74HC08 (or 74HC11 to have an extra line for open-drain chips.)
/Andrew
deck65 - 6502 slab with screen and keyboard |
ПК-88 - SBC based on KM1810VM88 (Ukrainian i8088 clone) |
leo80 - simple Z80 SBC
nice65 - 6502 assembly linter |
My parts, footprints & 3D models for KiCad/FreeCAD
