It is currently Sun Nov 24, 2024 6:17 pm
PostPosted: Fri Apr 28, 2023 1:11 pm
There have been two interesting projects in the Cosmac Elf email list that I thought I would describe here. The reason is that someone more hardware orientated than me might find it interesting.
The first is a diode ROM which was pretty straight forward. It used a decoder IC plus some 1N4148's with headers to allow for changing contents of the ROM. I thought it was pretty slick, because he essentially built a low density programmable ROM that you can physically manipulate.
The second was a 16 bytes serial bootloader. Here the 1802 has an advantage over the 6502 because it has some I/O built-in. The bootloader downloaded a program from one of the external flag pins, and placed it into RAM. Then transferred control to the downloaded program.
The reason I found this interesting is that it created a batch programming environment with very little hardware. Now to actually use this you use another computer to feed in the serial data, but in principle a more primitive system could be built using paper tape or cassette tape.
PostPosted: Fri Apr 28, 2023 4:13 pm
Nice! (It's a good feature of the 1802, to be able to bootstrap. The transputer also had such a scheme... maybe the parallel propeller too?)
PostPosted: Sat Apr 29, 2023 11:00 pm
Yes, the Propeller chip boots using SPI from a serial EEPROM. It can also boot off its serial port from a host PC.
PostPosted: Sun Apr 30, 2023 1:18 pm
Z280 is designed to bootstrap from its built-in serial port. It was the inspiration for many of my SBC that have the serial bootstrap function.
PostPosted: Sun Apr 30, 2023 2:38 pm
The Transputer one is interesting - mostly because the means it works - there isn't a bootloader in ROM as such, but the microcode recognises commands send down any of the Transputers links just after coming out of reset - it's a crude debugging interface - read/write RAM and "go at an address". This lets you test RAM before loading code into it, then poke in a small bootloader, then run it. It seems crude but it was used to bootstrap 1000s of transputers in an array very quickly.
I do like the minimal PROM approach though - and knowing a 22v10 GAL can hold 40-50 bytes of ROM data might make an interesting challenge - a DIL EEPROM which are essentially "unobtainium" ...
PostPosted: Sun Apr 30, 2023 6:30 pm
Can 22V10 really holds 40-50 bytes of ROM? I routinely do serial bootstrap and/or CF bootstrap with 32 bytes of ROM, so perhaps 22V10 can do both small (and fast) ROM and some address decode? That’ll be interesting.
PostPosted: Sun Apr 30, 2023 7:19 pm
Well, I've not tried it myself, but this thread does suggest it's very possible:
viewtopic.php?f=10&t=3383&start=30&hilit=gal+prom
PostPosted: Mon May 01, 2023 3:49 am
Although I’ve not tried it with the 22V10 PALs, I did try it with the Coolrunner II CPLD family. I was surprised at how much of my soft-core’s microcode could be packed into these devices. The Coolrunner II parts are more like Programmable Logic Arrays (PLA) than the 22V10, but either part can easily function as fast small- to medium-sized ROMs.
Michael A.
Users browsing this forum: Google [Bot] and 70 guests
