The short answer is laziness: it's more ICs to solder and route, more testing and more chance of a mistake. The longer answer is I'm trying to reduce the ridiculous number of ICs I need in my build. Each one has complexity as it adds propagation delay (think two 4bit '161s into a an 8bit '541 and multiply that out to 24bits) and potentially more current draw and/or load on whatever is driving it. I might end up amplifying ringing that wouldn't happen in a single IC, need impedance matched resistors and more decoupling caps. Basically it's just more to think about in a project that, while a hell of a lot of fun, has gotten wildly complex.
And expense. Which makes the 22v10 almost a contender. The price of two 74LVC161s and a 74LVC541 is only a bit cheaper than a single ATF22v10. A bit off topic but I don't think I understand the 22v10 (specifically the ATF22V10C) as even at 100Hz frequencies the current draw sits around 150ma per chip - which strikes me as quite high. And means if I use a significant number of them I'm pulling amps.
[edit]I forgot to mention that the 74FCT191 exists and still readily available, reasonably cheap and fairly quick.
But it's also huge! Can't have everything I suppose
[Further edit]The 73HCT193 is the cheap IC, not the FCT. Oops
