It is currently Sun Nov 24, 2024 4:49 am
 Post subject: 74xx75 as clock divider
PostPosted: Sun Jul 03, 2022 1:17 pm
I've seen several places where a 74xx75 is used as clock divider.
There is no need of set/reset signals, as it's a D-type latch.
I want to divide DOTCLOCK (~8Mhz) from the C64 Expansion Port, to feed a w65c265s' FCLK (fast clock) input with half that clock speed.
The circuit would be like this:
Any experience or recommendation of a better solution?
Thanks.
PostPosted: Sun Jul 03, 2022 11:22 pm
Hello! I guess it depends on what you want to optimize for… from the datasheet, it looks like the '75 would work fine in a C64, but (a) you would end up with a bunch of unused gates, and (b) it's quite expensive (Digikey lists it at $3.50 CAD).
If these things don't matter, I wouldn't overthink it, especially for a single prototype… just wire one up and see if it does what you need. You can always go back and change things around, especially if you find that another configuration gives you some advantage that you discover at a later point.
There are a bunch of alternatives, again depending on what you want to do. You could use a counter (like, say, an 'HCT161), which is cheaper (~$1) and will give you other clock divisions (/4, /8, /16), for example.
PostPosted: Sun Jul 03, 2022 11:36 pm
Thank you very much. So a counter then, will do it. I'll take a look on that.
I just want to halve the clock coming from the C64 and have ~4Mhz, because ~8mhz is too much by now, and ~1mhz coming from PHI2 is maybe not enough, at least for FCLK (fast clock).
PostPosted: Mon Jul 04, 2022 12:38 am
A counter (such as a '161) is good choice. The '75 is not, as it's a transparent latch (ie, follow-hold operation, like a '373; not an edge-triggered, like a '374).
PostPosted: Mon Jul 04, 2022 12:46 am
My deepest apologies, I was thinking about the '74. Sorry for the snafu (and thanks, Jeff).
PostPosted: Mon Jul 04, 2022 1:07 pm
Thank you very much both of you.
PostPosted: Mon Jul 04, 2022 8:09 pm
I maybe too late, but I would suggest a 74LS93. It's a small package (14-pin) and will give you /2, /4, /8. /16. The other 3 divisions you can use for whatever.
Just be careful as the Vcc and Gnd pins are in odd places.
Users browsing this forum: No registered users and 49 guests
