Just an update on this series of boards, the Micro-PET, Ultra-CPU, and Ulti-PET:
These are essentially Commodore PET clones, but with many more features. This is a family of boards with a set of core features, and different additional features depending on the board variant.
The
Ultra-CPU core is based on my
CS/A bus system, and as an FPGA is used that contains the memory mapping, could be used in different types of system, not just the PET.
The
Micro-PET is the core, plus all the standard PET I/O, mainly IEEE488, keyboard, and tape (but without 9V), on a single 100x190mm board.
The
Ulti-PET finally, is a fully integrated PET clone, with many many features. Most notably, I used the
6502.org original SPI-10 specs and included a 5V (based on the VIA SR), and a 3.3V (based on the FPGA) variant. Also, an UEXT connector is on board, including I2C, 3.3V-TTL serial, and SPI (based on the FPGA SPI interface).
Specs are:
Ultra-CPU:* CS/A bus-based 65816 CPU board
* Up to 17.5 MHz 65816 CPU, with 1MB RAM (512k fast, 512k media RAM)
* 768x576 VGA with 16 colours out of 64, various modes incl. Colour-PET and C64-alike, incl. sprites
* USB host for keyboard and mouse
* DAC (DMA) audio output
* Port for SD-Card adapter (2 variants)
* Port for Network, with either Ethernet or Wifi options
Micro-PET removes the CS/A bus, but adds:
* Standard PET I/O, plus ability to work as IEEE488 device
Ulti-PET integrates, on top of the Micro-PET, the following features from other CS/A bus boards
* (Fast) Serial IEC, incl. ability to work as IEC device, based on the VIA SR
* RS232, plus 2nd TTL serial (shared with UEXT)
* Dual SID with mixer (that includes the DAC audio and the beeper); Speaker amp included.
* Keyboard shift lock / reset (needs Shift lock key on separate keyboard matrix position)
and adds these features on top:
* 2 Joystick ports, switchable between single- and dual mode ("stupid pet tricks" compatible)
* SPI-10 5V, SPI-10 3.3V, and UEXT extension ports (partially shared, see schematics), incl. I2C
* Fully functional Tape incl. 9V for Tape drive power supply
* Expansion ports for the CS/A bus - single wide port, single shortbus port for Ultrabus expansion board
* Accompanying bus extender board to use CS/A, RC2014, Apple-II, or C64 cards
The new revision of the UltiPET going into production:
File comment: picture of the Ultipet board
P.S.: Not all of the boards are already on github, but definitely will be soon. Open Source Hardware.
Author of the GeckOS multitasking operating system, the usb65 stack, designer of the Micro-PET and many more 6502 content:
http://6502.org/users/andre/
