It is currently Fri Nov 22, 2024 10:31 pm
Post new topic Reply to topic  [ 1 post ]
PostPosted: Tue Mar 22, 2022 1:38 pm
Full description on anycpu.org. Stub implementation of Wilson Mines Co Memory Module now available. I probably used the wrong footprints but variants directly compatible with Skinny 64K SRAM Chip, W24512AK-10 $0.50 (including shipping) are hopefully forthcoming.
If I'm sending one board, I might as well send others. Choose what you want from the full list but try to keep it under 2kg. No charge. Pay it forward.
If anyone else wants to make their own variants of the design, please use product codes as follows:
  • XR0284/D: 4*4 chip stacked 62256 32KB SRAM, 28 pin, 0.3 wide DIP.
  • XR0285/D: 3*4 chip stacked 62256 32KB SRAM, 28 pin, 0.6 wide DIP.
  • XR0286/D: 4*4 chip stacked 62512/W24512AK 64KB SRAM, 32 pin, 0.3 wide DIP.
  • XR0287/D: 3*4 chip stacked 62512 64KB SRAM, 32 pin, 0.6 wide DIP.
  • XR0288/D: 4*4 chip stacked W241024AK 128KB SRAM, 32 pin, 0.3 wide DIP.
  • XR0289/D: 3*4 chip stacked whatever 128KB SRAM, 32 pin, 0.6 wide DIP.
