Hello,
I need some help!
I just got a WDC W65C816SXB Development Board and I would like to directly connect it to my PC using USB to run Andrew Jacobs' w65c816sxb-hacker.
The README says "You will need a USB Serial adapter (like one of the cheap PL2303 modules with jumper wires sold on eBay) to establish a connection."
When I went to eBay and searched for "PL2303 modules" I found
USB To RS232 TTL UART PL2303HX Converter USB to COM Arduino Cable Adapter Module
https://www.ebay.com/itm/222528693981or something like
PL2303TA USB to TTL RS232 COM UART Module Serial Cable Adapter for Arduino
https://www.ebay.com/itm/224493165773or do I need something more like this
https://www.amazon.com/dp/B00LODGRV8Also, do I need to put any resisters or capacitors or can I just directly connect them to the pins.
Thanks in advance!
