With an EEPROM shortage and a MAX3421 SPI to USB bridge shortage, your over-the-air binary transfer system could become become very popular.
I'm glad that you note the lack of security. Some people are completely oblivious and would deploy a similar system in a critical environment. Even for prototyping, a robust checksum would be very worthwhile to reduce accidental or malicious error. Over-the-air signed binaries would also be worthwhile, either for an individual unit or a class of hardware.
A general note for video presentation is the journalistic mantra "Tell 'em what you're going to tell 'em. Tell it to 'em. Then tell 'em what you've told 'em." This can be applied fractally and some people are quite able to hide facts like Cantor dust in a huge amount of useless padding. When used productively, it provides an index and a rationale. I distinctly don't follow journalistic practice when I'm writing. My style isn't for everyone but some people prefer a rant and ramble. It is also quite easy to skip around text. When watching most video presentations, it is painfully apparent that more structure is required.
1980s training videos are often good examples of structure because it was hard and expensive to make any production. Casual efforts existed but they had very little distribution. 3M had a well structured (and awfully styled) video about innovation. I think that I found it via the four hours of MIT OCW 15.356: How To Develop Breakthrough Products And Services.
If you have 56 minutes spare, I recommend
Architecture of the CM-5, lecture by Daniel Hillis. Daniel Hillis very quickly establishes that the lecture will be a chronology and then draws minimal diagrams while describing the features and limitations of each iteration of massively parallel Connection Machine. At the end, you'll understand some of the quirks in CUDA. More importantly, you'll see that Danny Hillis is arguably following a 10 slide limit while using a chalk board for emphasis.
Richard Hamming's lecture about Hamming codes is more rambling but is also good because it explains rationale and development while giving career advice. Every other video on this topic is inferior; some entertainingly so. Regardless, it is directly relevant because it is the type of integrity check which reduces accidental or malicious error.
