It is currently Fri Nov 15, 2024 1:25 pm
 Post subject: Programming 6530
PostPosted: Sat Aug 27, 2005 6:12 pm
How can I program the ROM of a MOS 6530?
Sam
"OK, let's see, A0 on the 6502 goes to the ROM. Now where was that reset vector?"
PostPosted: Sun Aug 28, 2005 3:47 am
I downloaded the 6530 datasheet from the 6502 datasheet archive. As I thought, the ROM is mask programmed. That means it was programmed during manufacturing and cannot be reprogrammed. There are a few other options that were mask programmed also. You might want to look over the datasheet for all of the specifics. Here is the link:
http://www.6502.org/documents/datasheet ... 0_riot.pdf
hope this helps!
 Post subject: Re: Programming 6530
PostPosted: Thu Sep 01, 2005 10:46 am
As 8bit said, the ROM is programmed during production. This site: http://www.baltissen.org/htm/buildkim.htm tells you how to reproduce a Commodore KIM using normal available IC's. In this case a 6530 can be replaced by a 6532 and an EPROM.
    ___
   / __|__
  / /  |_/     Groetjes, Ruud
  \ \__|_\
   \___|       URL: www.baltissen.org
