WDC 65C51 disable echo mode
jfoucher
Post by jfoucher »
The datasheet says this on page 14:
Receiver Echo Mode (Bit 4)
A 1 enables the Receiver Echo Mode and a 0 enables the Receiver Echo Mode.
Is it a typo or is it really impossible to disable echo mode on this chip ?
Jonathan Foucher
Take a look at the Planck 6502 computer.
Re: WDC 65C51 disable echo mode
I think it should say,
  • A 1 enables the Receiver Echo Mode and a 0 disables the Receiver Echo Mode. [...]
I've never turned on or used echo mode.
fachat
Post by fachat »
In such cases it helps looking at the datasheets of the 'sister' chips like the R6551 etc.
jfoucher
Post by jfoucher »
Thanks for the replies. I think my code does not enable echo mode but I still get an output of whatever I send. I will double check everything and try to find where the problem is.
Jonathan Foucher
